Question about Toshiba 57HDX82 57" Rear Projection HDTV
Clean behind the screen.
It looks like we have cobwebs at the top of our screen. How do we get front panel off to clean, or can you?
  • moyo Apr 02, 2008
    same problem as packefan. cobwebs in the screen that need to be cleaned out
Hey,
to packerfan. yesterday i did some thinking. i had the same problem w/ my toshiba 57". cobwebs in the viewing screen. i found the solution to be simple. take the front panel off. it's just held on by some clips. remove the black cardboard cover that protects the wiring. it's simple just w/ a screwdriver. attach a feather duster w/ duct tape to a 2 ft. dowel or longer if your arms are short.there are several places you can go up to dust. i found that if you clean 1/2 of the screen then the other 1/2 you should be done all tolled in about 10 mins. presto! my screen has never looked so good.too bad it's taken me 3 yrs. to figure it out. hope this solution works for you as great as it worked for me!!!
Posted on Apr 04, 2008
Cobwebs inside screen
you need to take the top back off the tv. and mind the glass at the top of the rear part top it is very fragile, most of the projection tv have a side cover on each side so you can clean the rear of the screen, as you not said what type screen you have i cannot tell you further.
Feb 25, 2014 | RCA Televison & Video
Cobwebs proscan ps56700 inside screen
It can be done from the front but from the rear is actually more easy and safe--removing front screen and frame entails some danger of damage to the screens.
I have over many years of outside/home service calls encountered this.
As a outside technician I want the quickest and safest way to do this.
With set unplugged simply remove rear cover:
Use a swiffer type duster to reach up and inside and gently get all the webs out(do not use force when against the inside of the screens) and if the handle is long enough you will be able to remove all of the webs.
Also when doing this you will see with cover off 3 large black lens at the top of the chassis above the circuit boards.
They are the light source for your picture--clean them with a lens cloth or a paper towel with Glass cleaner sprayed on it---Do not attempt to clean the mirror in the rear as it is a film material and is easily scratched.
If the lens were dusty/dirty and then cleaned the picture will be brighter and sharper looking----that should be done about one time a year.
If you have questions make a comment here on this page(make a comment button).
Apr 21, 2012 | Proscan PS56700 56" Rear Projection...
My refrigerator runs almost constantly. Do I need a repairman or is there a simple maintenance that I can do?
Get behind it and clean out the cobwebs. A clean coil is a more efficient coil. You don't need to call anybody to clean it up.
Sep 07, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Cob webs behind screen
The frame around the screen just pops off. Unscrew the plastic holders from the chassis frame and the screen will come off allowing you to clean everything inside easily. The "2" thin screens are easily cleaned and put back on easily also. Don't do what I did and think the screens go into the front slot of your plastic brace, they slide easily into the wider slot. You'll also be able to clean the dust from the reflector and guns with Windex. Much better picture after wards, trust me. You would be surprised how much dust may have accumulated on the lenses.
Jan 31, 2010 | Philips Magnavox 55P9271 55" Rear...
Cobwebs behind the screen of a 55" projection screen. How do I remove screen to clean the TV? I have a Mitisubishi WS-55809.
Hello morsec,
You will need to remove the screws on the back of the top half of the TV set. This will allow you to remove the top rear half of the TV and give you access to the screen. Make sure you do not break the mirror that is attached to the rear of the TV set. Clean the screen with a damp non-abrasive cloth dry with a dry non-abrasive cloth. When finish replace the back of the TV and tighten the screws to hand tightness.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Cobweb in projection tv
take the back cover off as the mirror is attached to it then you can clean the mirror and the inside screen and colour gun lens's (3off) there should be 8 to 10 screws around the outer edge of frame and about 6 to 8 holding the screen portion to the chassis
Jul 23, 2008 | Televison & Video
Cobweb inside of TV
i did mention this in my problem post incase it can help you but in the event where you overlooked it try some dust-off it may help you better than it did me
Jul 05, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do i clean my screen
You can clean the screen from the back - take off the access panel. I clean mine once a year whether it needs it or not.
Apr 23, 2008 | Sony KP-53V80 53" Rear Projection...
Cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Mar 22, 2008 | JVC AV-48WP30 48" Rear Projection...
Cobwebs in the screen
pop the front grill off and you will see some screws onthe bottom of the screen. pull these out and the grey trim peice should pull right off.
Oct 14, 2007 | Philips 60PP9202 60" Rear Projection...
Toshiba 57HDX82 57" Rear Projection HDTV Logo
269 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
