Question about Alpine Car Audio & Video
I would like to purchase a paper copy of an operating manual for an alpine model #cde-sxm145bt stereo system
  • Alpine Master
  • 4,290 Answers
Vicki do you have a printer ?
or know someone with a printer
just download this
http://support.alpine-usa.com/products/documents/OM_UTE-42BT_CDE-SXM145BT_CDE-143BT_EN.pdf
and have acrobat reader on your p.c.
and print it out
Posted on Mar 19, 2018
SOURCE:
SOURCE: SET CLOCL
Hold in title button on the bottom right hand corner
Posted on Apr 16, 2008
SOURCE: alpine cde-7853
hold down display button until time is blinking, about 20 - 30 seconds. to change hour press 5 button, to change minutes press 6 button. get time set then press display button again.
Posted on Jun 18, 2008
simplemitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
etirbynnor
  • 655 Answers
SOURCE: adjusting the time on an Alpine CDE-9852
Hello bitterswe834,
To set the time, do this:
1. Press TITLE repeatedly until the time is displayed.
2. Press and hold TITLE for at least 2 seconds while the time is displayed. The time indication will blink.
3. Use the volume control to adjust the hours while the time indication is blinking.
4. When the hour has been adjusted, press MODE.
5. Turn the volume control to adjust the minutes while the time indication is blinking.
Hope this helps.
Posted on May 24, 2009
  • 2337 Answers
SOURCE: Wiring schematic for Alpine CDE-7856
Download user's guide and go to page # 20 for wiring diagram.
Posted on Jul 12, 2009
I have an Alpine CDE-SXM145BT car stereo. that will not play Bluetooth devices.
Have you had the battery removed at any time before this happened or been jump started ?
Apr 09, 2017 | Alpine Car Audio & Video
Does not power on
Check the fuse in the fuse box of your car and if that doesn't help there is a fuse on the back of the alpine unit. And if this doesn't fix the problem then most likely you have a bad unit.
Nov 03, 2013 | Alpine CDE-SXM145BT Bluetooth CD/SiriusXM...
Alpine cde-9842 clock set
  1. In the Clock priority mode, press and holdTITLE for at least 2 seconds while the time is displayed.The time indication will blink.
  2. Turn the Rotary encoder CDE-9846 only) or press "up" and "down" (CDE-9842 only) to adjust the hours while the time indication is blinking.
  3. When the hour has been adjusted, press the Rotary encoder (CDE-9846 only) or press MODE (CDE-9842 only).
  4. Turn the Rotary encoder (CDE-9846 only) or press "up" and "down" (CDE-9842 only) to adjust the minutes while the time indication is blinking.
  5. The time is automatically set 5 seconds after the minute adjustment.
  6. The time can also be manually set by pressing the Rotary encoder (CDE-9846 only) or press MODE (CDE-9842 only).
Download Alpine CDE 9842 Manual
Feb 05, 2013 | Alpine CDE-9846 CD/MP3 Car Stereo
Jus got my second-hand alpine cde-9880r,dont know how to change display color..any help?plz
http://www.alpine-electronics.co.uk/fileadmin/user_upload/manuals/car_audio_manuals/CDE-9880R/OM_CDE-9880R_EN.pdf
On page 20.
Mar 06, 2011 | Alpine CDE-9846 CD/MP3 Car Stereo
Cannot operate Alpine CDE 9881
Hello!
Hopefully this will help you out.  The manual for the 9881 can be gotten here:  http://vault.alpine-usa.com/products/documents/OM_CDE-9881.PDF
Copy the entire line into your browser, and you will have it.  Don't forget to save it to your system.  It is in PDF format, so if you don't have a reader, pick up one for free here: http://www.adobe.com/
Good luck with the "new" car and radio!
Ken
Jan 08, 2009 | Alpine CDE-9881 CD Player
Alpine CDE 7853 removal
remove the face and then the trim ring for face you should see 2 little pins on either side of the radio slide them up and it should slide right out
Nov 20, 2008 | Alpine CDE-7853
Older Alpine car stereo light problem
It's probably a solder in lamp. They can tend to be very tiny. About the size of the head of a paper match or smaller. If you're not good with soldering then I would suggest you go to a repair shop and let them do it. Good luck.
Apr 29, 2007 | Alpine CDE-9846 CD/MP3 Car Stereo
Car Audio & Video Logo
42 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
