Question about Syscan TravelScan 662
The computer recognizes the hardware, however scanner is not scanning. Have windows XP. How can I tell if the scanner is broken, there are no lights on it?
    President:
  • 1,383 Answers
Your scanner is ok.
But there is communication problem from computer to scanner .
For that
Check your usb cxable and usb port of computer working fine.
Try in another usb port.
If you have other port like parallel port then check it.
Check drivers of scanner are instaled proeprly.
Ig already installed then uninstall it and install again.
Also uninstall all usb drivers then restart the computer then it automatic install usb drivers .
you can uninstall usb drivers from computer with device manager.
Press windows key + Pause break key to see system proeprty then go to hardware then you see device manager then uninstall all usb drivers.
Posted on Jul 31, 2009
HP psc 2170 series scanner isn't recognized by Dell Dimension 4550.
the device (scanner) may not be supported by XP Pro or the drivers for the scanner have not been installed properly so that your HP can connect to it. if the scanner is new tech XP may be too old to connect it or its hardware work with it.
Apr 19, 2014 | Microsoft Windows XP Professional 2002 for...
I HAVE LOST CD FOR INSTALLATION FOR SCANNER PLUSTEK OPTIC Pro U12B. kindly tell how to install scanner in my computer
1.First download the scanner driver- ->Plustek OpticPro U12B driver(Windows XP ver.)_ 2.Save it somewhere where you will remember after download . We recommend that you save it on your desktop , so it will be easy to find ..
3.Double- click the file you downloaded .
4. Follow the on-screen instructions.
5.When it's successfully installed , please restart your computer
6.After you have restarted the computer , plug the scanner into your computer and it will automatically recognize the new hardware.
Nov 26, 2010 | Plustek OpticPro U12B Flatbed Scanner
Please, how do I install my flatbed mercury scanner 1200cu+. I cant find my installations disk
I found an Windows XP driver here: http://www.mercury-pc.com/download_file.php?option=file&item_id=2870. The documentation for the Mercury KOB 1200cu+ scanner indicates support for Win 98se/Me/2000/XP. On a newer Windows OS, it may not work but you can try and see if a generic scanner driver installs when you plug it into the computer. If it is recognized, scan using Windows Fax and Scan (File, Import from Scanner) or Paint (Import from Camera or Scanner).
I hope this helps.
Dec 16, 2009 | Mustek Be@rPaw 1200CU+ Flatbed Scanner
Scanjet 4370 is recognized in "My computer". But HP Solutions does not recognize it, saying "No HP device detected. Closing HP solutions". When I try to use scanner, a microsoft box opens and asks me if I...
Is HP Solutions on the internet? You are using the scanner on board and it works. Do I have this pictured correctly, if so, maybe you you have a good blocker that is over protective?
Aug 04, 2009 | HP Scanjet 4370
Computer can't connect to scanner
If you are using Win XP there's another way of testing it with your computer for to check if your scanner is damaged or just a simple
software issue:
Usually for Epson it came with an Application called "Epson Scan"
> with the scanner connected to your Computer try to scan using a diff Application like PhotoShop or MS Paint
> to scan using Paint
Click on Start / All Programs / Accessories ( click and open "Paint" )
> from Paint click on File / and click "From Scanner or Camera" and it will open a scanner wizard., just follow the step by step procedure on how to scan.
note: if you have a diff. imaging devices ( like web cam ) it may ask you which one to use., make sure to select your scanner.
> if it can acquire an image using paint or diff application., there's no issue with the scanner unit.
> if it cannot acquire an image using paint or diff application., your scanner is broken / damaged.
To fix the issue with Epson Scan
> Uninstall "Epson Scan" from Control Panel / Add or Remove Programs / disconnect the scanner unit "USB cable"
> Control Panel / Administrative tools / Services ( look for Windows Image Acquisition < WIA > click on it and restart the service.
> Close all the windows and restart your computer.
Download the Twain Driver from the Epson Website
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88043&prodoid=63070037&infoType=Downloads&platform=Windows
downlad > TWAIN Driver and EPSON Scan Utility v3.12A
epson12526.exe )
note: if you don't have internet you can use the cd that came with scanner...
> after it is installed your computer might restart and then:
> click on Start ( right click on My Computer / left click on Properties ) on the Properties window click on Hardware Tab / Device Manager / on the device manager window look for "Imaging"
under Imaging look for your scanner ( right click on it and click on update driver., select this time only hit next / select Install the software automatically ( recommended ) hit next and it will update your scanner driver.
> Close all windows and Launch Epson Scan
Mar 22, 2009 | Epson Perfection V200 Flatbed Scanner
Scanner 5300c
Did you install the software/driver? Did windows recognize your scanner in your hardware profile? Don't use the software from HP, It sucks. If the HP software is not working correctly, then Use the one provided my your operating system works great. Go your Control Panel, Printer and other Hardwares and click Scanners, make a shortcut to your task or start menu and Scan Away. For Faxes, etc. import in outlook or other email client, etc.
Jan 19, 2009 | HP ScanJet 5300C Flatbed Scanner
The scanner doesnot work
Unplug your scanner usb on your system. then attach it back to your computer then power on your scanner.
Do right click my computer>properties> in system properties select hardware> then, click the Device Manager> tab, then select the first listed there on USB controllers. then click the scan for hardware changes> this icon can find above or click Action menu and select >scan for hardware changes.
restart PC. Hope you can do it. And it will help you.
thanks.
Jul 29, 2008 | Artronix Technology Artec ViewStation AS6E...
Nikon Scan doesn't recognize scanner
I have the same problem (on XP, Nikon Scan 3.1.2) ... IF I turn the scanner on before the computer (or turn the scanner on and then reboot) then Nikon Scan recognizes it. Can't say I'm happy with the solution, but it works consistently for me.
Apr 18, 2008 | Nikon LS 2000 Film Scanner
Computer does not recognize my scanner
The current software is 1.0.3. It does work with this scanner and XP.
You should install the drivers after removing the existing driver and software. Do not hook up the scanner until the drivers have been installed.
It might not show up under the Cameras and Scanners section in Control Panel but it will still work.
When you open Elements make sure your scanner is on with the door closed. Go down to where you import and look for the scanner to be listed. It will take a minute or two to go through its calibration routine and then you should be able to scan with it.
Jan 18, 2008 | Minolta Dimage Scan Dual II Film Scanner
No image obtained on preview scanning or actual scanning
First thing to do is un install and reinstall the software. Then consider - what other software could be running the could conflict[A graphics program for example]is to try another software for scanning if available. The other thing to consider is the age of the scanner- if it is from the DOS era-95/8/ME- then it will like as not not run- there is a firmware problem. Scanners have a controller chip - DOS era devices are looking for DOS commands - and they are getting NTFS commands- various makers like Microtek tried driver fudges- but they did not work. It has to be a NTFS scanner for NTFS commands.
Jul 11, 2007 | Microtek ScanMaker 6800 Flatbed Scanner
Syscan TravelScan 662 Logo
246 people viewed this question
Top Syscan Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Syscan Office Equipment and Supply Expert? Answer questions, earn points and help others
