Question about Kodak EasyShare M1033 Digital Camera
How do I change my camera from using the internal memory to using the SD card?
    Master:
    Sergeant:
  • 460 Answers
Just remove the card and take photos, it will get stored on the camera, But before taking photos chk if ur camera has built in memory.
Thankyou
Appreciate a good rating from you..
Posted on Jul 31, 2009
  • Mohamed Ismail
    Mohamed Ismail Jul 31, 2009
    Thankyou
How do I change coolpix s52 to change from internal memory to sd card?
Try formatting the SD memory card using the camera's Menu setting.
May 04, 2012 | Nikon COOLPIX S52 Digital Camera
Need help with moving pictures from internal Kodak Z740 to SD card
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
Jul 18, 2011 | Pentax Optio S Digital Camera
How do I clear the internal memory?
This should do it - this comes from the manual Formatting will do what you want.
Formatting an SD Memory Card or Internal Memory This utility formats the internal memory (or memory card) and erases all stored images and data. 1. Press the button to turn on your ViviCam 3785. 2. Press the MODE button twice to enter [ ] Playback mode. Then press the button to enter the Playback menu. 3. Select [Delete] by using the / buttons, and press the button. 4. Select [Format ] by using the / buttons, and press the button. 5. If you want to format your SD memory card or the internal memory choose [OK] by pressing / buttons, then press the button to confirm.  To cancel the action, select [Cancel] instead.  [No Image] pops up after the SD memory card or internal memory has been formatted. Note:  Be sure the SD memory card is properly inserted into the camera before formatting it.  To format the internal memory, be sure to remove your SD memory card first.  Formatting will erase all information (even unrelated , non-camera data) from the memory/card.  For complete compatibility, be sure NOT to select FAT 32 as the file system when you format the SD card in your computer. Memory cards formatted in FAT 32 file system will not be recognized by this ViviCam 3785.
Jun 16, 2011 | Vivitar ViviCam 3785 Digital Camera
When I try to take a picture, it says memory full. But, when I try to look at the memory it says no file. I tried using the disk, installing software, formatting it.. Nothing works. The SD memory card is...
Format the SD card make sure the camera is set to place the new files on the SD card and not go to the internal memory. What I fully expect is the camera has defaulted to using the internal memory which is now full of files/pictures and needs to be set back to SD card. To get the pictures from the internal memory to your computer you need to load the pictures one by one from the internal memory to the SD card. Then take them from the SD card ether to a card reader to the computer or download them from the camera to the computer.
Dec 25, 2010 | Vivitar ViviCam 8025 Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    How do i switch off internal memory
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
      After you have done so I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 17, 2010 | Kodak EasyShare C613 Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
      1. Menu
      2. Cam settings
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    How do i change internal memory to card memory. the camera seems to bestuck on internal memory mode.
    Menu, Camera Settings, Internal Memory has to be changed to AUTO.
    The camera can only detact the memery card if in the camera otherwise it will automaticly go back to internal memory.
    M1033 Memory card support : SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
    Pls. rate me good if you find my advice useful
    Nov 24, 2009 | Kodak EasyShare M1033 Digital Camera
    How do i transfer pic from the internal memory to the memory card
    www.kodak.com/global/en/service
    FOR MANUAL DOW[section title] Choosing Internal Memory or SD/MMCCard
    The camera offers two options for storing pictures and videos:
    Internal Memory —Store pictures and videos in 16 MB internal
    memory.
    SD/MMC Card —Store pictures and videos on a card. The number/length
    of pictures/videos depends on the size of the card. Purchase accessories at
    a
    dealer of Kodak products or visit www.kodak.com/go/dx6490accessories. For
    storage capacities, see page 114.
    Managing Your Storage Location Setting (after inserting the card with power
    OFF)
    1 Turn on the camera.
    2 In any still or video mode, press the Menu button.
    3 Press to highlight Image Storage , then press the OK button.
    4 Press to highlight an option, then press the OK button:
    Auto (default)—the camera uses the card
    if one is in the camera. If not, the camera
    uses internal memory.
    Internal Memory—the camera always
    uses internal memory, even if a card is
    installed.
    5 Highlight Continue, then press the OK button again.
    The setting remains until you change it and applies to all camera
    functions.
    6 Press the Menu button to exit the menu.
    NLOAD.
    Jul 09, 2009 | Kodak EasyShare C643 Digital Camera
    BenQ C850 Switch from internal memory to sd card?
    Try other SD card. 99.99% sure that the card is not good. Borrow your card to someone to check your card with his camera,or Format the card from C850 Menu.
    Jan 30, 2009 | BenQ DC E600 Digital Camera
    Kodak EasyShare M1033 Digital Camera Logo
    Top Kodak Cameras Experts
    Tony
    Greg Cann
    Greg Cann
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
