Heavy Machinery Logo
J
Jim hendrikx Posted on Mar 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On hitachi ex120-2 how. Change from jd to cat control
toddgilbert
Level 3:
Top Expert:
  • Heavy Machinery Master 6,360 Answers
  • Posted on Mar 19, 2018
toddgilbert
Level 3:
Top Expert:
Answers
6360
Questions
5
Helped
1526417
Points
27737
You will get your solution and all info on service info, repair info, parts info, wiring/electrical/fuse diagrams, error/fault codes, torque specs, PCV,
owner's/service/repair/parts/maintenance manuals etc everything
this website www.reliable-store.com
it's a very good website for vehicle problems even as old as 1991 ford..
Change input on Hitachi LCD TV model LE65K6R9 without remote?
I'd unplug/disconnect the Roku and after 30 seconds try the control button on the back. If you can change the input do so, then plug the Roku back in. Until you use the input button on the back to change input to Roku, you should be able to use the other buttons on the back to control the TV. If this does not work, unplug both the TV and the Roku. Wait maybe a minute, then plug the TV back in and follow the above instructions. Here are other alternatives: Using physical buttons: You can find the physical buttons on the left or right back side of the Hitachi TV. Using these keys, you can change the input, adjust the volume, or turn on Hitachi TV without a remote. Press the Input button located at the back or side of the Hitachi TV. The list of connected sources will appear on the TV screen12.
Using external devices: Connect a wireless keyboard or mouse to your Hitachi TV and change the input1.
Buy a universal remote: You can buy a universal remote to control your Hitachi TV and change the source.
I would like manual for 55R80 hitachi tv I am having problem I can not change hdmi mode the tv is stuck. On HDMI 1
Down load at Hitachi web site or Google it also on remote control change with input button
Tv won't turn on. red led does turn on though.
If it is under warranty, call Hitachi. If not, try using the remote control to change the INPUT until you see TV selected. Another option, look behind TV to see if all wire are still connected correctly, maybe your cat walked behind it and pulled out something.
I just recently upgraded my PC to window's 7. Every time I attach my Hitachi camcorder (model # dz-mv750a) its reads it, but when I got to pull files from it the screen goes black and I have to force...
Try uninstalling the Camcorder's software and reinstalling, that way the drivers and updates needed for Windows 7 are insured on the reinstall.
Hope this works.
-- JD
2helpful
Looking for the switch to change from cat controls to john deere controls on a cat 315 excavator
Hey Rawhide.....have a Cat 315 myself and looking to do the SAME thing (just got it yesterday). Talk about confusing. I'm used to JD too, so if you hear.....please let me know and I'm going to try to find out from the guy I got it from 2morrow. I believe that it's a simple and easy fix but you never know. My email is [email protected] . Use Cat 315 in the header. Thanks (or anyone else too) Fran
1helpful
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
1helpful
2answers
Code and instructions foremote radio shack 15-2114
I lost my manual for my remoet cat,no, 15-2114. Could someone help me with the code for a hitachi 60" TV?
fandrewszion
Top Heavy Machinery Experts
ADMIN Andrew
ADMIN Andrew
Dmitry Isayev
Dmitry Isayev
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
