Question about Sony Playstation 3 (PS3) Console
HOOKED TO INTERNET WITH ETHERNET CABLE DIRECT FROM WALL TO PS3. STILL GET DNS ERROR. ANY SUGGESTIONS?
  • 1 more comment
  • cruisers1944 Jul 31, 2009
    ARE NOT USING A ROUTER HAVE CONNECTED TO PS3 WITH ETHERNET CABLE STRAIGHT TO WALL.HOW DO I GET DNS NUMBERS AND WHY DO I GET DNS ERROR
    LAST ANSWER WAS FULL OF JIBBERISH. THERE IS NO ROUTER
    DSL
    THERE IS NO ROUTER
    IT IS A DSL CONNECTION AT WORK
    STRAIGHT ETHERNET CABLE TO PS3
  • Sony Master
  • 19,396 Answers
To start try restarting the router.
Ensure that you have correct configuration on PS3, reset network configuration and make a new connection.
Go into DNS setting on PS , try entering the DNS server addresses manually in the PS3 network settings. The primary DNS must be the one given by your ISP.
If that does not work, enter into router control panel, entering router IP into Internet Explorer. In there try disabling firewall, and restart the router. If that works, add an exception with PS IP in router firewall.
Also try upgrading router firmware to latest release. If you have a different router, configure it on the network, and test it with the PS3.
Posted on Jul 31, 2009
  • Ginko
    Ginko Jul 31, 2009
    Hi there, please be patient, thanks.
    if you are at work there is a firewall that may block the PS.
    In any case if the problem is the DNS error , the first thing to do is to get the number of the local DNS.
  • Ginko
    Ginko Jul 31, 2009
    To discover DNS you may need to ask someone, or check network settings on a computer connected to the network.
    If you have a computer connected you can also use an utility like this one.
  • Sony Master
  • 3,866 Answers
Check your router settings make sure you demiliterize your ports on the ps3. You can slo try connecting ti up directly to your broadband modem if you do not get the error its with the router and thus you have to make sure the settigs are correct.
Also make sure you are DHCP if your a static route then you need to put you ip and dns servers in the router as it will not pick them up automatically.
thanks
  • 11,896 Answers
Enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server
Or change your router 1) Your SSID (typically the SN of the modem/router) 2) WEP 'enabled' and the WEP key.
I just bought my sony playstation 3 the problem is that I can't seem to hook it up to my internet it goes to an office beside my house I don't even see my hughesnet satelite on there and i don't know what...
  • Connect your PlayStation 3 game console to your cable modem using an Ethernet cable. The length of the cable needed depends on the distance of your PS3 from your cable modem. The Ethernet cable plugs directly into the rear of your PS3 console, as well as the rear of your cable modem.
  • Power on your PlayStation 3 and your cable modem.
  • Move to the Settings option on the XMB (short for cross media bar--another name for the PS3's home menu).
  • Scroll down to Network Settings and press "X" on the controller.
  • Select the Internet Connection option and make sure it's set to Enabled. Then scroll down to Internet Connection Settings and press "X."
  • Select "Yes" when the console notifies you it will be disconnected from the Internet. Select the "Easy" setting method. Your PS3 will configure your settings automatically. Press "X" when prompted to save the settings and test the connection.
  • This is the Plastation Tech Support No.
    800-345-7669.The working hrs are Monday - Saturday 6am-8pm PT
    Sunday 7am-6:30pm PT
  • If you need to configure your modem to the Hughesnet manually then you will require this settings TCP/IP Configuration
    IP Address 192.168.0.2 Subnet Mask 255.255.255.0 Default Gateway 192.168.0.1
    Preferred DNS Server 66.82.4.8 Alternate DNS Server 66.82.4.12
Jan 08, 2010 | Sony Playstation 3 (PS3) Console
Resetting router
Sounds like the router's DNS settings got clobbered. I've heard of this happening before when UPNP is enabled.
There should be a reset switch (usually concealed iside a hole) on the back or bottom. That'll get you back to factory settings. Reconfigure as needed and I suggest you switch UPNP OFF, there is never any real need for it.
Oct 11, 2009 | D-Link DGL-4500 Wireless Router
Same problem as everyone else :"DNS error and some numbers"
Go to internet settings and manual set up then try these dns settings.
primary dns 4.2.2.2
secondary dns 4.2.2.1
~I find i dont always need to use the secondary one.
hope this helps :)
Jul 07, 2009 | Sony Playstation 3 (PS3) Console
DNS Problem On PS3
try setting up your network in auto.
go to internet connection setting an select easy, it should setup itself.
May 02, 2009 | Sony Playstation 3 (PS3) Console
When i try to hook up the ps3 to the internet it finds the IP but when it says connecting to the internet it won't connect it says that it is a DNS error? but i do not have any ethernet cables hooked up to...
check your pc they will be there Winxp users go to Control panel open network connections then open local area connection click on properties scroll down to Internet protocol (TCP/IP) hightlight it and click properties, your dns settings should be there!
Or Contact your service provider for the DNS settings!
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
PS3 internet connection problem
if wireless you have got to go to the router and un plug the ethernet cables and the power cable then plug them back in then it works i have had this problem
Apr 09, 2008 | Sony Playstation 3 (PS3) Console
No internet ?
When you connect your ps3 with a ethernet cord you need to restart your ps3 when its connected. If its wireless you may need to check your router settings.
Mar 05, 2008 | Sony Playstation 3 (PS3) Console
Need help with ps3 internet hook up
The ps3 wifi is very finicky --
While the ps3 scans for a hotspot turn the router off then on so the router aquires the ps3.
Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit.
If all else fail use the ethernet cable to attach it to your laptop. Then run network setup on the laptop and add the ps3.
Nov 10, 2007 | Sony Playstation 3 (PS3) Console
Ps3 hook up to the internet
I have a problem. I have everything hooked up and when i go for a connection test it says my connection has failed because there is an DNS error. What is a DNS? and what do i have to do to fix it?
Sep 08, 2007 | Sony Playstation 3 (PS3) Console
Ps3 wireless
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Jun 29, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
