Question about Hayward 100,000 BTU Pool Heater H100ID1 - Above Ground
Hello: I have a H100ID1 gas heater. It will not start all the time when T-stat is turned on. And when it does work after it gets to temp., and tries to start again after T-stat calls for heat it will not. You can hear it click but not ignite. I?ve also checked continuity on T-stat with power off. And it seems to be working. Could it be the ignition module? PS: I?m NYS Lic. Electrician. Any help would greatly be appriciated.
    Champion:
  • 246 Answers
Electrician and pool do not mix LOL
Posted on Sep 01, 2009
My infared heater no loner works by remote or manually pusings buttons. running constant
you may have a stuck bi metal t- stat try tappiig lightly on top by controller if you unplug prior to tapping onit it shound still come on when plugged in agian if its verry cold and comes on when pluged in then get a $4.00 timer and set at intervals tempory fix til you can locate a t-stat ,you may want to send in for service if you dont have skill set to repair it.
Feb 18, 2015 | Rinnai Desa Vent-Free Infrared Gas Heater:...
I have a Hayward H100ID1 heater. I turn the gas shut off on and I know there is gas going into the heater. But when I turn the heater on and it sparks, the is no gas smell and it does not light. What can...
first be sure your water filter is clean and the pressure gauge works.....you may need to bleed the gas line to get fresh gas to the unit, you can use soapy water to check, that the fitting leak free, after bleeding at the block
Jun 04, 2013 | Hayward 100,000 BTU Pool Heater H100ID1 -...
How to winterize the h100id1 hayward pool heater
disconnect or blow out with air and antifreeze then pull freeze plugs and disconnect pressure switch and turn off gas
Sep 23, 2012 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Heil heating unit ran out of lp will no restart fan runs no fire up
if you ran out of lp you my need to purge the line. shut off power and crack gas line as close to gas valve as you can.try a 5 sec. count. reconnent and check connenction with soapy water for leaks. if none return power and turn t stat up. if it cycles and doesn't lite turn t stat down and then recycle may take 2-3 times. the fan runs on a timer. when the t stat is in demand the fan will run by turning the t stat down below room temp the fan will shut off.
Jan 29, 2011 | Heating & Cooling
It doesn't want to shut off and we have no heat?
when you say it doesnt want to shut off i'm guessing you mean the fan. the fans run on a timer when the thermostat calls for heat it will come on 90-120 sec.later. turn your t stat down below room temp and it will shut off in 30-60 sec.your ignitor is most likly bad. turn your t stat back up and look at it. it should glow. furnace will try to light 3 times,you may hear the gas flow for 3 sec.during this cycle. if no glow good chance that is your problem and you will need to replace it.be carefull it is very brittle and breaks easy if tapped. be sure to turn the t stat down again or the fan will start running again.
Jan 26, 2011 | Coleman Propane Forced Air Heater...
My nephew has a Hayward H100ID1 pool heaterThe problem is
I changed the ignition module. It has been working fine since.
Aug 02, 2009 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Open Questions:
See all Hayward 100,000 BTU Pool Heater H100ID1 - Above Questions
Hayward 100,000 BTU Pool Heater H100ID1  - Above Ground Logo
239 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
