Question about Packard Bell Audio Players & Recorders
Hi I'm looking for a wiring diagram for the Packard-Bell FPS 100
Hi I'm looking for a wiring diagram for the remote/Volume controller to this speaker system as the wires have been pulled out by my children, only 2 remain attached.... Thank-you
SOURCE:
informatica
  • 1114 Answers
SOURCE: Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 14, 2007
  • 5 Answers
SOURCE: jbl wiring diagram
OK
See you CPU's backside  you will find  two different speaker input saket (in green ,yellow or pink) fix your speaker pins in their colors   and the speaker will work
Posted on Dec 22, 2007
devocap
  • 201 Answers
SOURCE: speaker wiring diagram
Hey there retgrunt, the information is at this location to download. the actual number on the guide is not the model you indicate, but the setup I believe is the same. I hope this helps Good luck!http://www.usersmanualguide.com/panasonic/dvd_home_theater_sound_system/saht70
Posted on Jan 28, 2008
headman333
  • 82 Answers
SOURCE: installing speakers
Friend first you have to check on your recycle bin if those files you have deleted is still there, if it is still there you have to restore those files.
If you are using sound card and you have your driver with you just install the driver and carefully read and follow its instructions. then there you go.
If your PC has a built inn sound card and if you are using windows OS and you have a windows media player driver then install it by carefully reading the instructions.
After doing this restart your computer and you can use again your speakers.
P.S. if this is be of help please rate me. Thanks!
Posted on Jun 25, 2008
SOURCE: Creative Inspire 5.1 5200 Remote Wiring
mine goes from left to right with light up and headphone socket close to you
green
light green
black
yellow
white
red
black/grey
blue
i also have a problem with my speakers
the volume seems to get gradually softer until theres nothing. it happens all the time and i constantly must re adjust.
Posted on Jul 23, 2008
Turn up volume
you'll have to click on the button in the lower-right corner wich looks like a speaker. then you adjust the bar. higher is louder lower is softer
May 30, 2013 | Packard Bell Computers & Internet
How do i improve the sound on my packard bell kav60
If increasing the volume levels does not work then connect an externally powered speakers to the headphone socket on your laptop. These speakers will give better sound quality than laptop speakers.
Feb 11, 2012 | Packard Bell Computers & Internet
I have no sound on my packard bell
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Mar 01, 2011 | Packard Bell (030069) Sound Card
Hi i need to get drivers for my laptob Packrad Bell
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 14, 2011 | Packard Bell Speaker Computer Speakers
I can get no sound from my computer atall. device "multimedia audio controller" has no driver, I am unsure which driver I need to install and where I can get it from - my computer is a packard...
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 16, 2010 | Packard Bell (030069) Sound Card
Packard bell itwin I have reloaded everything yet there is no No audio device or sound
you might have to get a portable usb sound card if you mean dont have a sound card installed or
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 05, 2010 | Packard Bell (181368) Motherboard
Need help getting sound from my inbuilt speakers!
Make sure you have the right power source.  Amps make a difference,  If it requires 1 amp and you are only putting in 200 mA, then you might not have enough "juice".  You can test the speakers using an MP3 player or something of similar sort through the earphone jack.  If the speakers work, check you sound card functions.
Jun 02, 2009 | Packard Bell (160248-01) Computer Speakers
Packard bell fps100 flat panel speakers
I am in the same situation as Simon and would appreciate help. They are Packard Bell speakers, called FPS-100
Dec 03, 2008 | Packard Bell (030069) Sound Card
No Sound
Look for device manager in the control panel to check if you have a sound card, look for an option to check its health. But first if you are not experienced volume might have been set to zero that's the first thing to check, volume icon is on bottom right of screen. right click and open to check volume setting
Sep 05, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
77 people viewed this question
Top Packard Bell Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Packard Bell Audio Player and Recorder Expert? Answer questions, earn points and help others
