Dell Vostro 400 Gives 2 Beeps after research it means a memory problem but all this happened after i took the memory out and put it back in so what is the problem?
  • messawood Jul 31, 2009
    also no input shows up on the screen
  • 23 Answers
Make sure the memory is seated correctly. Both sides of the memory should click in. I would try 1 memory stick at a time if you have more than 1. If it was not seated correctly and you turned the machine on, you could have damaged it. Try different slots as well.
Posted on Jul 31, 2009
    President:
  • 1,383 Answers
Because your RAM not sited perfact also some dust there.
First pull out the RAM then clean it from dust also clean dust from its slot on motherbord.
Then refix again try both RAM Memory slot on motherbord.
  • kishor
    kishor Jul 31, 2009
    Reset your bios settings to defaults you can reset bios settings with cmos cell.
    Pull out CMOS cell from motherbord for 15 minutes then resited cmos cell again then all settings are defaults.
    Then check.
    If still face problem then open processor fan and resited processor fan and processor .
    Processor in in bottom of processor fan.
Hard drive beeps
was your vostro 230 third generation? meaning, did it use DDR2 memory before or always had DDR3? They are not compatible. 2nd generation computers cannot use third gen parts. cpu, ram, most none of that type stuff. the motherboards are different and cannot change. if it was ddr2 memory you have to use ddr2, not ddr3, hope that helps.
Nov 19, 2013 | Dell Vostro 230 Safe space Tower w monitor...
I get two beeps at start up with nothing on the monitor and then have to restart again and then it finially comes up after three to four restarts.\r\n it goes 2 beeps 2 beeps I took the memory out and put...
Two Beeps indicates "No memory modules detected" as outlined in the service manual. Either you have bad memory or you memory slots ( or motherboard memory circuit) are bad.
Jan 04, 2011 | Dell Inspiron 530 Desktop Computer
I own a dell. intel865 foxconn motherboard. there is on 512 ram and i want to put 4 kingston 512 or at least 2. but there is only multiple long beeps, phoenix bios
You have to make sure that the memory you put on each socket is a DDR266/333/400 memory. The max capacity of your motherboard is up to 4GB, meaning 1GB of each socket.
Oct 12, 2010 | Foxconn 6100K8MA-RS Motherboard
Dell vostro 200 4 beeps then with f2 starts
here is the explanation of what can be possibly wrong,
1 long, 2 short - Video adapter error: Bad or improperly seated video card
Repeating beeps Memory error: Bad or improperly seated RAM
1 long, 3 short-Bad video RAM or video card not present
4 short Keyboard communication failure: Bad keyboard controller or keyboard
This is what the typical explanation is. To avoid assumption, i will need info on *********** board...thanks,
Mar 19, 2010 | Dell Vostro 200 Mini Tower With 20" Flat...
4 short beeps on vostro 200 monitor shows black?
http://support.dell.com/support/edocs/systems/vos200/en/index.htm
the above link will allow you to download pdf versions or view HTML versions of the Dell manuals for your machine.
4 beeps is RAM read/write failure
if you recently installed new RAM (memory) you should check to be sure that it is compatible. If not, you might just have a loose memory stick.
just remove and re-install memory modules making certain to seat them firmly.
!!!! Very important ..before touching memory.. be sure to discharge any static from your body - by touching anything grounded (I usually leave my tower plugged into a grounded outlet and make sure the rocker switch to the for the power supply(the switch on the back of the computer) is turned off.
Aug 09, 2009 | Dell Vostro 200 PC Desktop
Dell vostro 400 2 beeps in bios post test
Hi...
The cause of beeping is the memory problem. maybe the memory stick is not inserted correctly. If your memory stick will not correctly inserted it will damaged the memory slot. Try to use the other slot, if the same thing happen. You memory slot will be damaged you need to bring you motherboard to the computer repair center. Ask first how you will pay, if the labor cost is high. its better to buy a brand new motherboard.
Regards.
ICmanServer
Aug 01, 2009 | Computers & Internet
Vostro 400 doesnt boot
try reseating your ram and make sure their in the proper slots.
Jul 31, 2009 | Dell Computers & Internet
Vostro bios post beeps
Either your memory sticks are bad or, you have too much memory in the slots. Computers can accept a lot of memory but they can only recognize a certain amount. Make sure you don't have too much.
Jul 31, 2009 | Dell Vostro 420 Desktop Computer
Won't boot..getting 2 short beep codes..have tried memory that i know is good.
Its the problem with the memory only. the memory u get from dell will noit suite ur pc. try changing the same type and speed memory
Apr 20, 2009 | Dell Vostro 200 PC Desktop
Dell vostro 1000 will not turn on
remove the memory cards and wipe the golden ends with an erraser and than put them back in and issue will be resolved ... if that doesnt help... if there are more than one card than remove them again and reseat one card at a time and you will find the culprit and you have to change it and in case of one card you have to change that
Feb 09, 2009 | Dell Vostro 1000 Notebook
Computers & Internet Logo
878 people viewed this question
David Payne
David Payne
