Question about Sceptre X9G-NagaIV 19" LCD Monitor
Monitor appears to be dying. It is taking longer
Monitor appears to be dying. It is taking longer and longer to turn on (the green LED light flashes off and on for up to 2 minutes). Had this problem with another monitor of this brand/model before. Can anything be done to fix it?
  • 1,684 Answers
If you can solder you should be able to repair the unit. The problem in most likely bad capacitors in the power supply. If you go to our web site at:
www.ccl-la.com/monitor_repair.htm we have pictures of what to look for and replace. Just open the monitor back and get to the power board, replace any that look like the pictures and you should be back going. If you don't want to do the repair yourself we do offer a repair service contact me at tech@ccl-la.com if you want us to do thhe work.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 31, 2009
Hi, if I change my computer to my Nissan 300ZX 1986 I have to reset my computer or simply change it. Thank you for answer.
There is no re-setting. You just change it out. Be sure and disconnect battery before unplugging the ecu. It's a simple swap and go.
If yours is like my '87 Sentra, there is no trouble code capability, but there are limited diagnostic functions. The red and green LED lights and the diagnostic switch (on/off), can tell you if problems are present in the system or not. You just have to follow the diagnostic procedure.
Here's how: Make sure diagnostic switch on ecu is off. Run engine at 2000 rpm for 5 minutes, at no load. Look at green led: if it flashes at least 5 times in 10 seconds (that is the oxygen sensor making it flash), turn car off. Turn diagnostic switch on. Turn key to on, do not start engine. Check led's: if red is off and green on steady-No problems present in system.
If the red light is on and green light is flashing, post back and I can furnish the rest of the diagnostic procedure-basically, you will be checking voltages and resistance of all solenoids and relays the ecu controls. The green led may flash in two different sequences (either longer flashes and short pauses, or longer pauses and short flashes) when in diag. mode (with the red led on), and that will lead you down two different diagnostic routes. Pretty simple, really, and pretty effective. Took me hours and hours before I realized I even had this diagnostic function.
Aug 18, 2013 | Nissan 300ZX Cars & Trucks
Have dell d610 battery light flashes 4 times red then one green, can't unplug
I would take note of the message you are getting and buy a new battery. I believe the red flashing lights mean that one or more of the cells in the battery are dying, and it's best not to turn off alarm lights like these. Did the battery hold charge for a longer period than one hour before you started to see the flashing light warning?
Apr 22, 2013 | Dell Latitude D610 Notebook
Nissan pulsar 1987 n13 the ECM light came one and the car cut out and won't start again and I need to know where the ECM is
Hi, the computer is under the passenger's seat. Code extraction procedure is pasted below.
READING CODES Modes will not switch while the engine is running. The ECM automatically switches to MODE I when the ignition is switchedOFF.
1984-90 Vehicles With Dual LED System
The self-diagnostic system has 5 modes. To switch modes, switch the ignition ON and use a screwdriver to turn the mode select switch through the access port on the ECM. The inspection lights will begin to flash. When the desired mode has been entered, turn the screwdriver fully counterclockwise. The red LED and green LED perform different functions in different modes.
Mode I-
This is the normal vehicle operating mode. The green LED will indicate loop status. If the green LED is not blinking when the engine is running, the vehicle is in open loop, or the HO 2 S, O 2 S, or sensor circuit has a malfunction. If the green LED is blinking, the vehicle is in closed loop. If a malfunction takes place, the red LED and the MIL will glow, indicating a malfunction has occurred.
Mode II-
Both the red LED and green LED are used to monitor mixture ratio feedback control. The green LED will function as described in MODE I. If vehicle is in open loop, the red LED and green LED will remain on or off. In order for results to be valid, vehicle must be in closed loop. In closed loop, the red LED remains off if the system is running rich, comes on if the system is running lean, and blinks at the same time with the green LED if system is within 5% of the exact air/fuel ratio.
Mode III
-When this mode is accessed, the codes stored in the ECM's memory will be flashed by the green LED and red LED on the side of the ECM. The red LED will light first. This is the first digit of the trouble code; the green LED will flash next, showing the second digit of the code. For example: 2 flashes of the red LED followed by 1 flash of the green LED corresponds to Code 21.
Mode IV-
This mode is used for checking the throttle plate (TP) switch, starter, and vehicle speed switch status. When the TP switch or starter switch is activated, the red LED will briefly flash as the status changes. For VSS status, the green LED will remain off when vehicle speed is less than 12 mph (19 km/h) and come on when vehicle speed is greater than 12 mph (19 km/h).
Mode V-
This mode represents a real-time diagnostic test of the crank angle sensor, ignition signal and the mass airflow signal. The malfunction code will be displayed only when the malfunction occurs and will not be stored in memory. The output code will appear as a single or short string of pulses. Count the number of pulses for the malfunction code.
1 pulse-CMP sensor signal lost or noise in signal 2 pulses-MAF Sensor signal abnormal 3 pulses-Fuel pump circuit shorted or open 4 pulses-Ignition signal lost
Apr 19, 2011 | 1987 Nissan Pulsar
The monitor will not show a picture the led is flashing green
* If the issue is visible in the monitor STFC (Self-Test Feature Check), the monitor is defective. * If not, the issue is with either the video card driver or the video card.
* Turn off both your PC and monitor * Disconnect the monitor from the PC (either the white DVI or the blue VGA. They should never be connected at the same time to one PC) * Turn the monitor on * The floating Dell red/green/blue/white dialog box should appear on a black background * Check for the issue
Mar 02, 2011 | Dell E173FP 17" LCD Monitor
Hp desktop wont turn on worked two days ago? Turned it off and when i tried to turn it back on ---nothing. A green led light in the rear of the tower is flashing ???
check if the monitor is on.check is the fan is making noise.If not then the power supply has problem.what appears on screen?
Jul 10, 2009 | HP Pavilion dv6000z Notebook
Black screen flashing power led
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
May 08, 2009 | Computers & Internet
Acer AL 1715 monitor flashes 2x and dies
LCD panels use cold-cathode fluorescent bulbs to make the light necessary for them to show images. What you're describing is something I've seen in panels where the bulbs were dying or dead. it's also possible that the controller for the bulbs is also on the fritz.
Jan 08, 2009 | Acer AL1715 17" LCD Monitor
Blank screen, led lights on, intermittent beeps
take out the RAM of your laptop, put it again,
also check the display on external monitor through vga port
Oct 20, 2008 | HP Compaq nc6000 Notebook
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Sceptre X9G-NagaIV 19" LCD Monitor Logo
165 people viewed this question
Top Sceptre Computers & Internet Experts
Robert Veldman
Robert Veldman
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
