I have a Craftsman Blower (Model 358.794964) that stalls when I try to turn the choke off. It starts fine and will idle but as soon as I try to turn the choke off it dies. Also, I can't increase the throttle (can't get it past half throttle) without applying more choke. Any thoughts??
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
The carburetor needs a simple adjustment. unfortunately, it requires a special tool. any good shop should have the tool, or it could be under warranty if it's less than 2 years old
you can buy that tool for 8 dollats on amazonhttp://www.amazon.com/Genuine-Poulan-Wee... i know it says poulan weed eater but the screws are the same
The high speed jet needs to be adjusted. turn it out untill it runs good
