Question about RTO AquaScape 4500 GPH Pump
Aquascape 4500 pump trips breaker when plugged in
My water garden pump works but trips the breaker when I plug it in.
    President:
  • 1,486 Answers
Water getting into pump.Thats what is triping it.
Posted on Aug 01, 2009
Where to buy a 20' power cord for Aquascape Pro 4500 pump?
Maybe try to just buy a 20' extension cord cut off the connecting end and hardwire into the unit.... ?
Oct 26, 2012 | RTO AquaScape 4500 GPH Pump
I need seal kit for aquascape pump 7500
www.thepondoutlet.com
Call or email, they will either sell the seals or tell you where you can find them
Sep 05, 2011 | Ultra Max Aquascape AquaBasin, Pond or...
My Aquascape 4500 pump immediately trips the GFI when I plug it into an outlet. This happens both when it is submerged and out of the water. The impeller is not obstructed.
The seal has failed allowing water into the sealed motor unit and it is now shorted to ground...in other words the unit is shot and needs to be replaced.
John
Apr 07, 2011 | RTO AquaScape 4500 GPH Pump
Pump runs for about 3 to 5 minutes and then cuts out the breaker. The outlet is good because I've checked it with other appliances.
You have checked that sure thing, but if you have that pump on a shared circuit that thing draws more amps than normal appliances or is competing with another appliance and popping the circuit. Try isolating the pump and also make sure the circuit can handle the amp load the pump is giving off. Hope this is helpful.. Good Luck!
Aug 20, 2010 | RTO AquaScape 4500 GPH Pump
Torpedo pump...I have one when I plug it in...it trips breaker
I had the exact same issue. I left mine out for the winter and when I plug it in, the breaker trips. My warranty was up so my friend took it apart. The seal had broken alowing water to leak into the bottom the pump where the wires connect to top of motor. This is supposed to be water free and is protected by several seals.
I am currenlty trying to put sealant where the cord goes into unit to stop water from going in. I will let you know how that works.
One tip my friend recommeded is to make sure there is no stress on the cord as it appears this seal is weak and and kind of stress will break it. hope this helps -- Rob
Apr 27, 2010 | RTO Cal Torpedo Pump 7500 Gph
I have a AquaScape 4500 GPH Pump it has worked fine. Today I spent all day cleaning out my pond. All I did was lift the pump out of the pond and spray the muck off it. After completly cleaning the pond and...
Where the wire goes into the pump there is a o ring thatis probably leaking and any sort of water the motor might be getting is tripping the breaker. You probably have it plugged into a gfi and it sense very low amounts of water, and trips, You can determine by plugging it into a regular outlet and it should work. But definently fix the oring at the point of entry on the pump
Apr 17, 2010 | RTO AquaScape 4500 GPH Pump
Aquascape 4500 not working
Typical with these pumps, pumps I have rebuilt that have done the same thing what happens is the bearings get loos and cocks the armature that is why it won't spin. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Apr 25, 2009 | RTO AquaScape 4500 GPH Pump
GFI for pump keeps tripping...
no you need to put 60amp breaker in house panel box
Jan 15, 2009 | Beckett Water Gardening Beckett Statuary...
RTO AquaScape 4500 GPH Pump Logo
266 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
