Question about RCA R52WH73 Projection Television
Our 52inch rca tv started looking like a rainbow
With double vision and the screen is bowed
    President:
  • 788 Answers
Your symptom sounds like at least one damaged convergence IC.
If you have a good low wattage soldering iron ~ 45W (available at radio shack) you can perform the repair yourself, and this will most likely take care of the entire issue.
I like to remove the board that the IC’s are on so that I can unsolder the connections and clean then up using solder wick (this is also available from radio shack). Removing the board is not a real issue as the connectors are all labeled with an alpha number, so that you can connect them back real easy. There are three in the middle towards the front that I like to mark with a sharpie as they are the red green and blue convergence coil connections (they are all the same size in a row). Just mark them with slashes, like I, II, III, or something like that. If you mix them up it is not a big issue, you can test swapping them around until the picture lines up.
Please be sure to remove the entire white heat sink compound on the heat sink and apply an even coating over the back of the new IC’s. You should also bolt them down before you solder them in so that you have them at the correct height.
There are two very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
The IC’s are large and black, you cannot miss them. They will usually have an STKXXX-XXX number on them.
This repair from a good technician will normally run from $250.00 - $300.00, and sometimes more depending on your area.
There are several schools of thought on the replacement of parts and I firmly believe that you get what you pay for, so don’t buy the cheapest IC’s that you can find. One company I worked for tried this and it only caused more work for the technicians, as we had to replace them with the more expensive ones in the end. I would think that you should be able to find these for around $60.00 each. If you can find the exact
Hitachi part, or Sanyo, even though the numbers on the front are the same, and they look exactly like the $10.00 ones, they are better and more reliable.
I usually order my parts from Andrews Electronics in
California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 31, 2009
Panasonic rear projection 52inch cinema vision 1080i hdtv looks 3D with double vision red, blue and green how do I fix
Replace the convergence chips--should be stk-392-110's in the Panasonic.
I have start to finish free instructions for this repair based on the model number----a email address will get them for free.
Jun 06, 2012 | Panasonic Televison & Video
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
How do I get the double vision out of my tv
double vision? is this multicolored. red green blue? is the picture bowed. Have you tried going to setup in customer menu and adjusting convergence, Both manual and autoconvergence.
Oct 22, 2010 | RCA HD52W56 52" Rear Projection HDTV
Rainbow showing up at bottom and top of screen creating double and triple vision
IM GUESSING ITS A LAPTOP SCREEN OR COMPUTER IT COULD BE SOME WATER TRAPPED INSIDE OF THE SCREEN LIKE CONDENSATION WHICH COULD MAKE A PRISM OF LIGHT LIKE WHEN YOU SEE A RAINBOW BECAUSE ITS SUNNY AND RAINING
Oct 08, 2009 | Philips TV Tuner Video Capture PCI Card -...
RCA REAR PROJ. SCREEN BOWS AT TOP AND COLORS DOUBLED
Hi, thank you for visit fix ya.
Resolder all connections around fly back ( check for open pico fuse).
if still problem, replace convergence board.
Thank you
Jul 27, 2009 | RCA HD52W58 52" TV
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
RCA Projection TV not working properly
All I need to know is how to shrink the picture!
Dec 21, 2008 | RCA P61830BL 61" Rear Projection...
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Home Theatre Model # P56927, Serial # 026451246
your convergence alignment is off,requires reaignment or possible replacement of module,this type of rca projection tv has a fault with the harness feeding the convergence module there is a fix for it,contact you local rca dealer,they must replace the connector because it bows and looses connection over time that creates other faults also/
Aug 22, 2007 | RCA P52926 52" Rear Projection Television
RCA R52WH73 Projection Television Logo
355 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
