Question about MGE XG VIPER ATX Mid-Tower Case
Hi i have the MGE XG VIPER (CAVIPERKR500W) pc case. it keeps beeping at me, 4 sets of 2 beeps, then a break. I have satisfied myself that it is not the motherboard bleep code, it has to be the case itself... what is causing this please??? oh it also swithches my pc down after half an hour, even with no power to the front lcd panel... which flashes error and the speaker and temp sybols flash... help please.. i love this case. :-((
  • freddycruger Jul 31, 2009
    i have eliminated everything from the case, as all the guts are now in another case working fully.. its definately a beep code from the case not the motherboard or anything attached to it.
    President:
  • 2,976 Answers
Depending on the bios, it will mean different things. I would check to see if the memory chip RAM is seated properly first.
Here's a list.
http://www.5starsupport.com/info/beep_codes.htm
http://www.computerhope.com/beep.htm
Posted on Jul 31, 2009
Viper 479V Viper Responder Remote how to program
open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
Apr 02, 2014 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Hi I have a viper 5701 it was working fine for about 2 years and today the car just stop beeping when I lock or unlock the car please help
Was this "beep" from the horn or a siren? The unit could be in valet. Look at the LED on the antenna. Is it on solid? If so the system is in valet. To remove valet, turn ignition on then off, press and release programming button on antenna.
If the LED is not on and, the "beep" came from the siren then, there is an issue with siren itself.
Jan 16, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Wiring diagram viper PC case
http://www.xoxide.com/xgbox-mge-viper-kr.html
http://www.xoxide.com/cases.html
hope this helps The MGE Viper Computer Case was been featured in Maximum PC Magazine December 2004 and granted a 9/10 score.
Jun 27, 2012 | Viper XG Red Viper2 Aluminum ATX Mid-Tower...
How to fully shut down the MGE MX5000 UPS?
1 - Press the "0" button (28) more than 3s. The buzzer beeps once, and the load is no longer protected by the UPS. It is powered via the Normal AC source. If the UPS is set in frequency converter mode, the equipments will not be powered. If the Normal AC source is out of tolerance, the UPS will generate a 10ms output calibrated break. 2 - For a full shutdown of UPS and connected load, the upstream circuit breaker (notincluded) should be set to the "0" position.
Sep 09, 2011 | MGE Pulsar MX 5000 (68505) UPS System
Back lighting for my viper 479v remote
you have to go in to the proramming mode of the remote to change this feature. you can access this by holding all 4 buttons on the remote at the same time. (or if you have the P button on the back you can hold it down by itself) you will hear 2 long beeps confirming the programming mode. at this time, you can change the settings by pressing 1 of the 4 buttons., each button will change a different function.
in no order------
1. Beep/vibrate or both
2. page or not to page
3.back light
4. hood, truck, or both
the remote will give 2 long beeps when it exits the programming
Aug 20, 2009 | Directed Electronics 479V Remote Gen 2...
Viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
May 10, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Front usb ports
Have a computer store look at it they may be able to help you put the wwires in the corect spot.
May 03, 2009 | XG Viper 2 ATX Mid-tower Gaming Case...
MGE XG VIPER ATX Mid-Tower Case Logo
430 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
