Question about Kodak Easyshare M753 Digital Camera
There is something wront with my lense!!
I turn on my camera and it says "lense error 115,1,0,0" what do i do?
    President:
  • 2,761 Answers
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
Testimonial: "thanks"
Canon ixus hard reset
Do you mean 'Factory Reset' if so you should find something similar in the camera menu
May 17, 2014 | Canon IXUS 115 HS Digtal Camera
Canon ixus 115 hs memory card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 09, 2014 | Canon IXUS 115 HS Digtal Camera
In the middle of taking pictures, all of a sudden my Nikon P100 will become blurry and then the Lense Error message will come up saying, "Lense Error: if the lense cap is on the camera, turn the...
Could be sand particles getting into the seams around the lens barrel, binding it up. Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 08, 2011 | Nikon COOLPIX P100 Digital Camera
Finepix j27 When the camera is turned on "Zoom error" message appears and lense is stuck in an extended position. When the power is turned off, the lense remains extended. Do you know how...
hi, Zoom Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
or you might send it out to a service centre, the charges are generally just the serviceing charges as no new parts needed.
hope this helps
cheers
May 05, 2011 | Cameras
Lense won't extend when camera is turned on
lens has been damaged and it's most likely not worth repairing. lens can look fine but internal damage will require more money than it's worth. recommend replace
Sep 25, 2009 | Cameras
I dropped my camera in the sand and the lense won't close. When I turn it on it makes a buzzing sound and states ''Lense error, restart camera'' and then turns off.
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Aug 18, 2009 | Canon PowerShot SD1000 Digital Camera
My Nikon 7900 has a lense error. WHEN TURNED ON IT SOUNDS LIKE SOMETHING IS SLIPPING AT THE LENSE, THE LENSE DOES NOT COME OUT, THEN IT SAYES (LENSE ERROR)
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 17, 2009 | Nikon Coolpix 7900 Digital Camera
Power issues.
you sdaid power surge on the laptop. Thus suggests that this may have affected the camrera. I would think a 'repair' if such is possible will be near the cost of replacement. Only Olympus can advise
Nov 10, 2006 | Olympus FE-115 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
98 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
