Question about IBM Office Equipment & Supplies
IBM correcting selectric - keys sticking and won't advance when keys or space bar struck
  • IBM Master
  • 3,594 Answers
By this time almost all selectrics need a good clean and oil the lubricants have turned to gum.
DickyO
Posted on Jul 31, 2009
Carriage does not advance when pressing the space bar or pressing a key. Does advance when depressing tab.
If you press a key does it type or try to correct? The escapement mechanism that allows it to move from space to space may be sticking and causing your problem. That mechanism just may need a flushing and lubrication. You will see a shaft that runs through the carriage. Try to turn it top to rear until it stops. if you hear a click then it has been turned the right amount. If it doesn't turn, then it is as far as it goes. Try hitting the spacebar and see if the carriage moves. If it moves, hit any key and see if it moves. if it moves, hit another key. If it doesn't move then your escapement mechanism needs to either be flushed and lubed or adjusted.
Nov 20, 2015 | IBM Correcting Selectric II
Space bar on sylectric 2 ibm typewriter is not moving the type
There are a few things that can cause your spacebar to not move the carrier. Do you hear any sound when you press on the bar? There are adjustment that may need to be made to the machine or perhaps there is something sticking in the mechanism. Unfortunately you mey not be able to fix this yourself as these machines need a technician to properly repair and service the machine.
Feb 15, 2015 | IBM Correcting Selectric II
Typewriter keys sticking
Your Selectric may need cleaning.
Apr 02, 2014 | IBM Correcting Selectric II
The return key sticks on my Selectric II
Under the R. black plastic dust cover there is group of cams and arms spray the two sets of arms and the cams with WD40 this shouls free up the arms.
DickyO
Mar 09, 2010 | IBM Office Equipment & Supplies
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II Works fine except space bar stopped working recently. (Can't make a space--pressing the key has no effect.) Is there anything I can do myself -- or, can you tell if this is...
Probably not much you can do it probabily needs a cycle clutch or at least adjusted. If you know how to remove the case you can try spraying with WD40 it may work but it will be temporary. DickyO
Jun 11, 2009 | IBM 3500 Typewriter
IBM Correcting selctric II keys are jammed
It sounds like the cycle shaft is not fully in home
position. With the machine OFF, try to turn the print shaft (the steel shaft with the single groove that goes through the carriage) top towards the back of the machine. Then turn the machine on. Try the space bar first. If it works, your machine probably needs the cycle clutch spring adjusted or replaced.
Feb 18, 2009 | IBM 3500 Typewriter
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
212 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
