Question about Microsoft Video Game Consoles & Games
Xbox360 won't go online after dvd rom replacement cat5 cable OK internet works on other xbox360
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 364 Answers
This is rare problem..this problem will be fixed with the help of xbox360 repair guide..click here for your reference
Posted on Dec 26, 2010
  • 1,525 Answers
Hello is the ip address ok try 192.168.1.1 good luck ps dont put any other information in
shaun
Posted on Aug 01, 2009
SAYS offline, HOW DO I GET IT BK ONLINE?
This is a network communications issue, most likely. If re-booting the copier doesn't change it, try rebooting the switch or hub it is connected to. I have seen Kyocera's take several minutes to report they are online following things as simple as being out of paper or a jam. Repeatedly trying things may cause it to stay in offline mode longer. If you are certain all panels are closed, paper and toners are in place, etc. and there are no codes or error messages, the machine should eventually be OK. If nothing works, it may be your cat5 cable or the socket in the machine. If the machine was moved with the cable still in, and it got a hard pull, there could be damage on the main board connections to the cat5 socket. that is sad and calls for board replacement.
Dec 11, 2014 | Copystar Kyocera Mita FS-C2126MFP Copier...
I cant connect my xbox live using a cable connection from my xbox to laptop how do i get the connction
That would actually be a "Line" connection. Or "Link". You will have to use a cat5 cord, and connect it to your internet source. (NOTE) just because logic says you can connect a laptop or pc to your Xbox360, simply because they use the same cords, doesn't mean it works that way. You can however use your laptop as a "Media server" in direct connection. This only allows you to transfer music and movies from your laptop to the 360. Not an internet pass through. Sorry.
Jul 16, 2014 | Microsoft Xbox 360 Console
Xbox 360 DVD Drive Not Reading Games Only DVD,CD after replacing the dvd rom
If you replaced the DVD-ROM drive yourself, some newer Xboxes do not recognize and/or function properly with older drives. I tried replacing a drive in an older Xbox with an older yet DVD-ROM drive, and it would not work. When replacing a DVD-ROM in an Xbox, it is advisable to use the same model drive, as the Xbox does strange things when you introduce different hardware. The url of a page is below that details the different drives that Xboxes use. See if your new drive is the same as the old one, and if not, that is almost certainly the issue.
http://www.llamma.com/xbox360/Xbox_360_DVD_Drive_Comparison.htm
Good Luck!
Jul 07, 2011 | Microsoft Xbox 360 Console
How can I connect my ps3 to my computer modem?
Here is a general guide I wrote. For Vista, however, I think you will have to go to the sharing tab instead of the advanced tab when you are browsing the properties of a connection...
1. Get a CAT5 or CAT6 crossover cable. The cable that came with the PS3 is a normal Ethernet cable, therefore it cannot be used for this operation.
2. Make sure you have two sources for network communication. For example, you can have 2 ethernet ports on your computer, or you can have a wireless card and a Ethernet port etc. It helps to draw out a connection blueprint such as this:
DSL Modem > CAT5 cable > Network Card 1 > Computer > Network Card 2 > CAT5 Crossover cable > PS3
3. Connect your computer to the modem and verify that you have an Internet connection. Then, click on Start, go to settings, control panel. Double click on Network Connections, and identify the connection to your modem (Network card 1).
4. Right click on the modem connection, and choose properties. Next, click on the advanced tab (Sharing tab for Vista users), and check the “allow other users to connect…” checkbox. After the checkbox is checked, click on the “Home networking connection” drop down box and select the name of the second network connection. Click OK and exit the properties window.
5. Finally, connect the CAT5 crossover cable from the second network adapter of the computer to the PS3, and voila, your Internet connection is now routed to your PS3. Please be aware that your computer must be on in order for your PS3 to stay online. In the long run, a router may be a much better device to use than your computer, since it consumes only a fraction of the electricity than your computer does.
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
Xbox360 can't play dvd game only dvd movie or cd
this is a common problem faced in xbox360..you have to use original DVD else the low quality DVD leads to damage your xbox360 lens...for further reference click here for repair guide....
Sep 04, 2009 | Microsoft Xbox 360 Console
Problems connecting to belkin
Connect directly to the modem with a Cat5 cable, and first ,see if you can get online. Then if you can, connect the router to the cable modem.Then connect directly to the router. see if you can get online through the router while being connected with the Cat5 cable.
If you cannot get online this way, we have to see if the problem is the router or the cable modem.
If you can get online while you are directly connecter, you may need to re-install the drivers for the USB Netgear device.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 29, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I am having problems at times, connecting on the internet, and other networks online. (i.e.)an icon would appear and suggest an error/data was made and being reported, and automatically swicth me back to...
Cable has changed it's policy and standards many times in the past
if you have a cable modem you will most certanly need to decide
if you're going to be using the cat5 ethernet connection or the USB connection cable
if you have an onboard ethernet adaptor or a PCI ethernet adaptor
it's best if you use the cat5 connection of the cable modem
if you have no ethernet adaptor , you will need to use the USB connection of the cable modem
and connect that to your computer , which will most deffinately require that you have working
USB ports and at least service pack 2 loaded to enable USB 2.0 , and a driver from the cable
modems driver CD
if you're using a router , use the cat5 connection of the cable modem
( make sure you contact your ISP to walk you through the setup proceedures )
Az Selah ..
Sep 17, 2008 | Computers & Internet
Network cable stopped being recognized
rj45 (cat5) sockets have 8 internal tensioned wire prongs, (six are used for cat5 ethernet)
use weakens the tension and they can be dislodged sideways vertically or disconnected from the internal cabling. Likewise solder connnections to the motherboard fail.
a possible fix is to power down the pc, and with a jewellers screwdriver ensure that all the internal wires are present, straight, aligned, and protruding across the opening.
If there are missing wires(broken) then the rj45 socket shoould be replaced at your local pc store, (not walmart)a796c91.jpg
Jun 28, 2008 | Sony VAIO PCV-RZ40C1B PC Desktop
No internet connection on my laptops
Please understand as I get very basic to start but things very obvious to you I cannot see.
Generally when including a router in a home network starting from the cable (tv) or the phone socket (dsl) in the wall with a phone wire plugged in. The next box is generally provided by your internet service provider and is a modem/something that connects to the phone line or cable. Then sometimes when only one computer exists computers are directly connected to the modem with an ethernet cable (looks like a fat phone wire with oversize connectors) or a USB cable (small flat retangular ends).
When you want to add a router for multiple computers. The computer gets disconnected. If a USB cable was used it is often replaced with an ethernet cable and that cable connects to the WAN port (probably separate from a block of 4 lan ports) of the router you bought (tell me if you have two routers -- that is a different problem). If your service comes from a cable (tv) company your router may already be properly configured. If however you have DSL service from the phone company the chances your router is correctly configured are less. To finish with the cabling story -- your computer then hooks to one of probably 4 LAN ports all in a block. Now if you are lucky power on all devices and boot up your computer and see if you have internet access. If you do great if not please provide me the name of your internet service provider or a link to their help/support website and I will see what I can do to assist in completing the router setup. Until your wired computer gets access to the internet your girls wireless connections will not work either. Once we get the wired connection working we will address the wireless connections.
If necessary unplug the router and plug the computer back into the original cable until we get the router working.
Dec 26, 2007 | Linksys Wireless-G WRT54G Router
Video Game Consoles & Games Logo
53 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
