Question about Whirlpool Washing Machines
When washer fills up it only fill with hot water. the cold water do not even run in machine. Then when it goes to the rinse cycle water is not filling up in machine. It comes out just alittle bit. is there something that is stop up. Like the cold water valve.
    New Friend:
  • 63 Answers
The cold water solenoid valve or the controller is defective. It is more likely that the valve is defective. Of course, check to make sure that the cold water feed is turned on.
Posted on Jul 31, 2009
I load washer it starts the wash cycle it goes through wash cycle fine drains water but does not collect water for rinse cycle it just idles. So I turn knob to spin and it spins until done.
If it doesn't fill for the rinse, I would say that the cold inlet valve has failed. Check that the cold tap is turned on and check when the machine fills for the wash cycle and see if it is taking hot or cold water. You will probably find that it is filling only with hot water. A local spares store should have the valve you need.
Sep 17, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Feb 20, 2013 | Washing Machines
Roper washer fills and washes then will not fill on rinse cycle but goes into washing dry
Run the machine with hot only, and then cold only. Post back your results.
Nov 11, 2012 | Roper Washing Machines
Washer only washes with hot water
consult your owner manual about you are unsure about if the machine is acting anormally
Some machines, is running hot water during cycles, other cold water during cycles.
God bless you
Jul 18, 2012 | Washing Machines
Cold water does not fill for the wash cycle but will fill for the rinse cycle
just a guess make sure hot water line goes to hot water inlet look close there is a difference and cold to cold cold will be blue
Apr 12, 2010 | General Electric WHDSR316G Top Load Washer
Cold fill washing machines
If your washer is the type that all rinses are in cold water only this would make sense that in the winter months when the water is at it's coldest the clothes will feel cold after the spin cycle.
If your washer has a warm rinse cycle and when you select the warm rinse option the clothes feel cold after the spin, then maybe the hot water supply line is plugged.I recommend disconnecting the hot water hose at the back of the washer and check the screen that is at the fill valve on the washer and make sure it isn't clogged with sediment or calcium build up or any other foreign material that would keep the hot water from entering the washer.If all is well there, suspect either the water temp selector switch or the hot water fill valve. Good luck !
Jan 23, 2010 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
No rinsing water coming in
There are 2 versions of this washer dryer, a cold fill only one and a hot and cold fill version.
If it is the cold fill version, it could be the water level switch that is malfunctioning, cutting off before the correct level is reached, or a sticking water inlet valve.
If it is the other version, then the same thing applys, plus the coil on the valve that controls the rinse cycle could be open circuit.
You need a meter to test the valve coils for continuity..
Make sure that there is actually cold water to the valve, if it is a hot and cold fill model.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
