Win Winfree Posted on Mar 18, 2018
Nelsonic unbranded nlc695 How set time and alarm
1helpful
Set time on alarm clock nlc695 nelsonic
Hi Joe.
this is all i could find.
How to set Nelsonic alarm clock? Press and hold the ALARM BUTTON to enter ALARM SETTING MODE. While still holding the ALARM BUTTON down, press and hold the HOUR and MINUTE BUTTONS until you see the time you want on your LCD DISPLAY. Release the TIME BUTTON and the Alarm Clock Radio will return to NORMAL TIME MODE.
USER GUIDE Alarm Clock Radio - Jazwares
jazwares.com/assets/pdf/userguides/13500_wwe_alarm_clock_radio.pdf Search for: How to set Nelsonic alarm clock?
or go to this link might help you.
how to Set time on alarm clock nlc695 nelsonic Google Search
How to set presets on nelsonic clock radio nlc 618
To set this alarm first ensure that when you press the Mode button several times the FM/AM radio does not turn on . If the FM or AM radio does turn on or the lcd displays "AU" press the Power button that is next to the Mode button 1 time (pressing the Power button toggles you between 2 settings). You should now be able to press the Mode button at least 3 times without the FM/AM Radio turning on.
Next you press and hold the Alarm 1 or Alarm 2 button and (while continuing to hold down one of the Alarm buttons) press the Hour or Min buttons to set the time of whichever alarm button you are holding down.
When you have the alarm time set you can release the Alarm 1 or Alarm 2 button and press the same button (do not hold the button down this time) to cycle between the types of alarms you can use. You will see the blue circle indicator move between Buzz and Radio when pressing the buttons (Blue circle on left side is for Alarm 1 and blue circle on right side is for Alarm 2). There is a third option as well but I'm not sure what the alarms will do if you set them to it because the blue circle indicator disappears entirely after cycling to Buzz and then Radio.
Hope that helps!
15helpful
3answers
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
 Grubhead
Grubhead
SmartAviator
SmartAviator
