Hm, I'm not able to locate a manual but may be able to offer some suggestions.
Remove the top thread from the machine.
AVOID OLD OR BARGAIN BIN THREAD!
Use the same thread in top and bobbin.
Be sure to use a brand new needle--needs to be compatible with the thread and fabric of the project..
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midway point.
Verify the bobbin is loaded and threaded correctly and it turns the correct direction.
Pull the bobbin thread up through the fabric before taking the first stitch. It also helps to hold both thread tails in your left hand when taking the first stitches.
Test your machine and tweak the top tension until the top and bobbin threads meet in the middle of the fabric. (Increased top tension will pull the bobbin thread up. Decreased top tension will allow the bobbin thread to pull the top thread down.)
How to Thread Necchi Sewing Machine
How to Thread Necchi 535FA 535 534FB 534 Sewing Machine and Bobbin Case (not your model, but the threading and basic instructions will be similar or the same as your machine)
How to thread Necchi model 535 FA sewing machine now with captions
SOURCE: Hi, I am unable to do a overlock stitch , elna l1
Check with sewusa for a threading guide and manual.
Look inside the font door of the machine to see if there is a threading guide.
SOURCE: Neccie BU Nova skips stitches
have you checked the needle to see if it's damaged
check also to make sure the needle is inserted in the needle clamp correctly
some times the needle & thread are not compatable---- try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
SOURCE: dial n sew 752 have
Unfortunately, i cannot locate any free copies but here is an inexpensive one.
http://ifixmachines.com/Deluxe-Zig-Zag-Model-65-752/View-all-products.html
It IS the correct machine manual.
Please rate Fixya
Thanks
