Was working fine then csme to use it this morning and although the motor is whirring away powerfully, there is virtually no suction! It's been emptied and there are no blockages anywhere
if you take out the dirt cup at the top there should be a half moon orange that releases. inside of this half moon is a washable filter. rinse with warm water and let it dry completly before putting back into the machine. this should restore your suction. hope this helps.
removed hair/lint & they still don't want to spin, suction seems to not be as good .. .I've...
(More)
removed hair/lint & they still don't want to spin, suction seems to not be as good .. .I've only had this for a month so I'm returning it to walmart this week!
Similar to other issues posted here, the vacuum shuts off completely after just a few minutes of...
(More)
Similar to other issues posted here, the vacuum shuts off completely after just a few minutes of vacuuming. Has been take apart and cleaned but doesn't work.
brushes won't turn. plan on replacing skinny belt. Also, brush control switch is stuck in the...
(More)
brushes won't turn. plan on replacing skinny belt. Also, brush control switch is stuck in the "off" position. have visually inspected and the lever appears to move and lock in. anybody know what the problem is? Are the two problems related?
