Back to:
Tags:
Jensen SC-570 Remote Control
Code for Samsung DVD (HT-DM 150) does not work with... (by 4 users)
posted by coachglen on Nov 24, 2007
I have tried many different ways to get my Jensen remote to access the DVD.....it will operate all other devices except the DVD......Help!!!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by josjan, posted on Sep 04, 2008
There is only 1 code listed for my brand of tv Sansui - 4061. This isn't working. I tried the auto scan too and fresh batteries. Any other recommendations
Comment by Guest, posted on Mar 23, 2008
Same problem, cant find a solution
Comment by Guest, posted on Nov 25, 2007
codes
Solution #1
posted on Apr 04, 2008
Not Rated (0)
Psionics
Rank:Guru Guru
Rating: 89%, 185 votes
try code 7000
Comment by Psionics, posted on Apr 04, 2008
if that doesn't work, try this:
The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
Turn on the component that you want to set up.
Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
Release the component key.
If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
Press "0" - "9" The green light will blink as codes are sent.
As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
If none of the codes turn your component off, return to step 2 and start over.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Code for Samsung DVD (HT-DM 150) does not work with my Jensen SC-570 remote:
I don't want to Accept this solution
Can you Help with these Remote Controls problems?
Remote Controls
I DON'T HAVE THE INSTRUCTIONS TO PROGRAM THE REMOTE FOR...
I just bougth a sony dvd home theater system,I connected...
I need a code for the Fortec life time ultra dish receiver...
what the code for coolsat 6000
Loading problems.
Repair Service
Find Remote Control Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
