Question about Bosch RotoZip RZ05-1100 RZ5 Base kit
Was using a rz5 roto zip and i believe iy over heated and will not turn on again first use ever
Same thing happened to me, when I took it apart I found that one of the electrical connectors has broken cutting power from the unit.
Posted on Feb 17, 2011
How do I change the brushes on roto zip z20
This does not appear to be a camera.
Oct 31, 2017 | Cameras
Spark electrode screws wont come off
use wd-40 or p.b.blaster to loosen but it is very (very) common to have to use a grinder or a roto-zip-saw metal cutting blade top cut-off an electrode bolt. even high-end grills are not using nigh-quality, expensive stainless for an electrode bracket or a screw.
Nov 07, 2013 | Dacor OB36 Gas Grill
When cutting 18mm ply wood using a straight edge after a few centimetres the cut curves under the material even with a new blade. thank you
Unfortunately that is just to thick of material to cut with a jig saw blade. Plywood is made up of several layers and your blade is trying to follow the grain on one of them. You can try a metal blade and high motor speed low travel rate, but it will quickly heat up the blade and warp it making your problem worse if you don't stop often. If you are trying to make straight and curved cuts, I have the best luck with a rotary cutter such as the roto zip, but plywood easily snaps the bits.
Mar 14, 2011 | Makita Saws
When i pulg in an turn on my roto zip model rev01 the lights come on but saw does not, took apart an brushes looks good, what else could be wrong?
depending on how old the saw is, the trigger may be shorted out. try and get into the trigger assembly to confirm.
Dec 19, 2010 | Bosch RotoZip Spiral Saw RZ10 - 2100
We have a unit installed in our RV. We did not use it last year. Just now, when we try to use it, we get the continuous beeping indicating a problem with the motor. I have taken the insides out to the...
Hi Al ,just read your posting.Now from the information in your posting you have removed the ROTO MOTOR from the machine is that correct?The roto motor has that blue impeller. If you haven't removed the roto motor then turn it anti clockwise and pull up to remove it.Once removed, remove all the water from where the roto motor was seated and check for sludge or old food. Make sure that the place where the roto motor was seated is clean and then replace the roto motor.Then try it on a cycle and see how it goes. please reply back and tell me how it goes and with the additional information.,
Jun 14, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I was cutting 1/4" wall tile. On the 3rd or 4th cut my rotozip RZ5 quit working. There is power at the outlet. The machine was pretty warm. Is there a fuse or thermal reset or do I need to send it in foer...
I have had similar problems in the past using my Roto-Zip on jobs. You may want to check the internal brushes in the machine have not been clogged with the dust from the ceramic tiles. The unit may have simply overheated from the stress of cutting the tile. This will also affect the brushes in the Roto-Zip. A can of compressed air may help clear any dust built up around the brushes. If they brushes are caked with to much dust, you may have to take the unit appart and manually clean the brushes. But, be careful because the brushes are spring loaded. Hope this information is helpful.
Aug 17, 2009 | Bosch RotoZip RZ05-1100 RZ5 Base kit
My ROTO ZIP RZ10 burned out after less than 3 hours (Total time, not continuous use) I'm using it with 1/4" shaft Kutzal bits for wood carving. I keep it clean, blow it out etc. Does this tool have a built...
Hi again, I think you will be happy you opted for the warranty solution, I told you they stand behind their products, Thanks for sticking with it and I'm glad we could help Fixya!
Mar 02, 2009 | Bosch RotoZip Spiral Saw RZ10 - 2100
Bosch RotoZip RZ05-1100 RZ5 Base kit Logo
354 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
