Question about Samsung Yepp YP-T9 Digital Media Player
Samsung YP-T9 is stuck on bluetooth mode F/W v1.28
When i turned the mp3 player on, it was on bluetooth mode and stuck, i reseted it, but it just went back to bluetooth. I tried to bluetooth with my blackberry, and it still didn't work. Please help!!!
SOURCE: Samsung YP T9
Well, another way is you can go to file browser and go to the file you wish to delete. once your at it hold menu until it says delete. press delete and it wil be deleted,
Posted on Jan 13, 2008
SOURCE: how do I get Blue tooth mode off of my SAmsung yp-t9j
press and hold menu button and a/b button at the same time for 5 seconds
Posted on Jun 24, 2008
SOURCE: samsung yp-t9
if u can try going to the samsung website then go to download centre then type in your mode of your mp3 player then download the latest firmware.i got a samung yp-t9 and i downloaded the latest firmware and it works like a mobile phone now and the blutooth is much stronger.
by rafix21c
Posted on Jul 24, 2008
SOURCE: Samsung YP-T9 Driver
Problem video
Posted on Dec 21, 2008
SOURCE: My Samsung YP-T9 MP3 Player wont turn on!!
press (rec+menu ) for trnin on the mo4 ! i just know it ! but for me doesnt charg and connect to computer ! i dont know what should i do !
Posted on Nov 16, 2009
Samsumg yp t9
Did you try pressing (A<->B/red dot) and Menu button at the same time? It resets it!!!
I had that problem and i sent it in and turns out it had a virus on it!!!!
If your warrenty still covers it, they will delete the virus and send it back as good as new. FOR MORE INFO www.samsung.com
Jan 11, 2009 | Samsung Yepp YP-T9 Digital Media Player
I want to reset my samsung yp-t9
Complete Solution - includes fix for Bluetooth.
You will need to execute a number of steps to do this:
1 - obtain a copy of the latest firmware from http://www.samsung.com/uk/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=mp3others&subtype_cd=&model_nm=YP-T9&dType=D&vType=L&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=YP-T9
or (even better) - go to the international site and download a copy of YP-T9 V1.80.zip
2 - Reset - Power off the yp-t9 using A-B and MENU pressed together - hold down A-B and press the POWER button to enter the low-level format mode - press LEFT LEFT RIGHT RIGHT UP CENTRE DOWN - the yp-t9 will now reformat - power off using A-B and MENU together
3 - reload firmware - Power on normally and connect to PC as a USB drive. Move the two files you just downloaded (MUON.ROM and SYSDATA.BIN) into the root of the USB drive - Safely remove the drive - Power on the yp-t9 and allow it to re-install the firmware
If you want to restore Bluetooth functionality you will also need to perform the following steps:
4 - pop the four rubber plugs out of the back of the unit - with a small phillips screwdriver remove the four screws - insert your fingernail into the seam of the unit on both sides and pop off the back - gently (slowly) remove the battery taking care not to place any strain on the connecting wires - copy dowm the 12-digit number on the label under the battery (starts 0016xxx...) - replace battery, back, screws and plugs.
5 - using text editor create a file with the 12 digits (use upper-case letters where appropriate) followed by <enter> key - save it as BT_MAC_ADDR.TXT
6 - connect the yp-t9 and open it using Right click on Start and Explore - find the yp-t9 and drag a copy of BT_MAC_ADDR.TXT into the SYSTEM folder - Safely remove - power on normally.
Hope this helps
Chris
Nov 19, 2008 | Samsung Yepp YP-T9 Digital Media Player
Help i have a Samsung YP-T9 and it froze
hold down the menu and play button at the same time to reset, should turn it off, then just turn it back on again
Jun 11, 2008 | Samsung Yepp YP-T9 Digital Media Player
Help
have you tried going to the bluetooth settings, and turning it off from there?
May 21, 2008 | Samsung Yepp YP-T9 Digital Media Player
My player is stuck on bluetooth mode.
I'm having the same problem....
Bluetooth mode appears every time I turn on my MP3 player and it's always necessary to turn off using menu+ab button.
Somebody uses info from this forum:
http://www.anythingbutipod.com/forum/showthread.php?t=11933 Unfortunately this didn't work to me...But if you want to try...good luck!
Jan 26, 2008 | Samsung Yepp YP-T9 Digital Media Player
How do I get Blue tooth mode off of my SAmsung yp-t9j
Jan 21, 2008 | Samsung Yepp YP-T9 Digital Media Player
Blue tooth mode
go to meny, bluetooth, bluetooth mode, and select off.
Nov 17, 2007 | Samsung Yepp YP-T9 Digital Media Player
Samsung YP-T9j won't turn OFF - Automatic Test Mode
Have you tried connecting it to your computer and attempting a Firmware re-load? There should have been a disc supplied which holds the software that operates your player. Firmware crashes are quite common on various machines, ans a re-load often sorts it. How old is the player? Worth checking the manufacturer's website to see if they've updated the Firmware.
Aug 29, 2007 | Samsung Yepp YP-T9 Digital Media Player
Samsung yp-t9
i cannot down load driver from your site for my ipod which model no-is yp-t9j and it capacity is 2 gb .
please give me advise how should down load this driver for my pc.thanks
May 29, 2007 | Samsung Yepp YP-T9 Digital Media Player
Samsung Yepp YP-T9 Digital Media Player Logo
542 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
