Question about Eureka Toolbox 1040A Canister Vacuum
Eureka tool box vac differences
What is the difference between a eureka tool box vac 1040, 1040A, 1040A2, and 1040B? thanks for your help!
3 Suggested Answers
MATRIX_MMX
  • 209 Answers
SOURCE: eureka upright vac. no suction
Dear wymanwong
Righteo, your problem is not exactly all that straight forward as i dont have a great deal of information to go on with regards to this type of issue and this make/ model of vendored appliance, so I will begin by explaining how the typical vacumn cleaner functions (in relation to your issue) and what can cause a fault of this kind.
The vacumn cleaner overall (unless is a liquid cleaner as well as a conventional dry suction unit) has the function of providing suction into either a chamber or bag which is either filtered or emptied, and the effects of loosing suction usually are effected by faults within filters, or directly through the motor that is normally powered through 240V~ (AC) within the UK or
115~ (AC) USA. Suction can also be lost through blocked exhaust outlets through the vacumn unit and also through any perforations or tears to a bag/ container that is used in order to maintain constant suction and storage of particles/ vacumned waste.
Now to investigate the fault you have in regards to loss of suction within your unit.
Firstly You should query the suction motor and the copper windings as these are both electronic and mechanical components that can be affected not only by general wear and tear, but also by various ingressions (such as water and liquids). Also heat can play a major role here, as motors can spin up to a large amount of revolutions per minute (RPM) and this will cause heat build up, add this to the fact that the windings inside most electric motors are made of copper, and you can quite easily discover that the motor will "burn out" as copper will break down at somewhat lower temperatures than other electronic components (this is also more likely as the casing of a DC/ AC motor is contained within a steel structure which is a good store/ conductor of heat).
The other factor that should be considered with vacummn failures is also associated with exhaust impedances. In otherwords, if outlets and filter channels are blocked, then overloads through the motor wiill be likely and the entire system may cease altogether.
In addition to this, investigations of the power supply and any power transformers within the unit should also be queried, along with any rectifiers (used for converting an AC signal to a DC signal for use with DC motors if necessary), as faults with these can occour even over short periods of time.
If queriying these components have returned no results to the fault, then there is always the option of attaing the service sheets for your appliance from the manufacturer/ vendor of your appliance. The best thing to do in this case is either to go to http://www.google.com or to the website that is listed for your manufacturer/ vendor. Now if google if your option, then there are a few keywords which will assist in your search for your service sheets and they are to simply either type your appliance name followed by the words "service sheet" or "repair manual" In addition to this, you can always contact the manufacturer/ vendor of your appliance directly by telephone and delegate with them in order to request user manuals and servicing guidelines, and given the fact that you have a small appliance, if you mention that there is a possibility you would order any spare parts through them, then i really cannot see a reason why they would decline offering you the servicing guidelines/ manuals at a low cost.
Now there are other things here that can be investigated, but in order for me to dfo this i will need full details of your appliance model number and maufacture code, along with full details of the fault, as accurate as possible. Also photographs of either the machine or any/ all of the internal components will greatly help as direct visuals will aide not only in the identification of your make/ vendor model, but also may give a visual clue of what could be defective within your appliance (for example scortch marks on the wiring that supplies your vacumn motor etc) But any pictures supplied will need to be of a high resolution and quality.
Well I do hope that this brief explanation will provide enough information for a fixya or even a total unit overhaul in the most cost effective manner, in addition to this i do hope that i will hear from you in the somewhat near future as so i can find out more about your fault and indeed if you have managed to resolve it elsewhere (and even how this was done).
I am here most days and nights and any contact to and from me will ensure that I endeavour to resolve your technical issue in the most appropriate way for you.
In the meantime, i do hope you take care, and look forward to hearing from you soon
yours sincerely
Oz
Here on demand for all your technical needs
Posted on Apr 14, 2008
SOURCE: Eureka central vac 's power stopped won't start again.
I took to dealer I bought from . He examined it. The motor is gone needs new one. Thanks, Ann
Posted on Feb 07, 2009
Where is the reset button the eureka the boss smart vac
There are many different models of Boss Smart vac so I can't say for sure without your model number but it most likely does not have a reset button. It may have a reset switch built into the motor.
Feb 26, 2017 | Eureka Vacuums
There is smoke comming out of my eureka pet pal vacuum cleaner every time i shut it off. and it does not suck up dirt.
Assuming it does not need emptying, then it sounds like a dangerous electrical fault. Recently similar thing happened to me, (different vac cleaner), and if I'd left it on any longer I'm told that it would have burst into flames. Be careful.
Nov 26, 2014 | Eureka Pet Pal Bagless Vacuum
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
Type of belt for it?
Your Eureka Whirlwind model 4489 uses the Eureka Style U belt. There are several different U belts that Eureka makes, including a generic one that's made by Eureka under the Smart Choice name. Eureka also makes a Eureka Style U belt Extended Life, apparently increase the life of your Belt.
Here are links to all of the Eureka U belts that will fit your model:
Generic Eureka U Belt made by Eureka for Smart Choice Brand
Standard Eureka U Belt Part 54312
Extended Life Eureka U Belt Part 61120
If you have any questions, or need help installing this belt, please just reply using the comment section on the repair page here on Fixya, and I'll be more then happy to answer any follow up questions that you may have.
If you found this helpful, please be so kind and rate the repair, or leave feedback for me, this is greatly appreciated by the Fixya community.
Thanks,
Chris Jones
GoVacuum.com
May 17, 2010 | Eureka Whirlwind 4489 Upright Vacuum
Where can I get a fiter for my GE Combination Bagless Vac model 106687
Greetings,
Your GE is actually made by Eureka for Wal-Mart. Wal-Mart owns the GE brand for vacuum cleaners, and they have different manufacturers (most always Eureka) make vacuum cleaners specifically for Wal-Mart, but in actuality it's really a Eureka vacuum cleaner in terms of the parts (most of the time, in this case for sure).
Your GE model 106687 uses Eureka Dust Cup Filter Part Number 61518. Here's a link to Amazon for the filter;
http://www.amazon.com/Eureka-Model-106687-Filter-61518/dp/B001DPLYAG/ref=sr_1_1?ie=UTF8&m=A13YM4FUDXTJG6&s=generic&qid=1269298852&sr=1-1
The parts Diagram for your vacuum cleaner can be found here;
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/GE106687.pdf
This will give you all of the Eureka part numbers for your GE Stick Vac. I hope that this was helpful to you. If you found this helpful, please be sure to rate the answer as helpful by clicking the 4 thumbs up icons in the top right hand corner.
If you need any other parts, please feel free to contact us.
Thank you very much,
Chris Jones
GoVacuum
Mar 22, 2010 | GE Combination 106687 Upright Vacuum
Need manual for Eureka Powerline Plus Model 9730 Type A - missing "door" that covers tool access port on body of upright motor...any ideas? This causes dirt to fly out unless tool hose is placed in...
Maybe you have already solved the problem this late in the game. Manuals for Eureka products can be found on http://www.eureka.com. Your local hardware store will have a bunch of different sizes of plastic caps in the plumbing section normally used for capping pvc tubing. If the outlet is round like an upright I had a few years ago you can pop one of these on and it'll do the trick. The cap shouldn't be more than a dollar or two, plus if you ever do want to use the tools again you didn't do any permanent damage to the port. Hope this helps!
Jan 26, 2010 | Eureka Powerline LiteSpeed 5845 Upright...
Battery Pack for the Eureka Boss Model 93B
tHE 96 F IS ALMOST THE EXACT SAME AS THE MODEL YOU HAVE. THEY HAVE THE SAME POWER TO THEM THE BATTERIES WERE JUST DIFFERENT
Jul 18, 2009 | Vacuums
Jan 24, 2009 | Eureka 1810 Central System Vacuum
I replaced the belt on my eureka 4870 vac and set it for carpet, but the brush will not turn?
Check that you have put the seal caps at the end of each brush roll side properly - it fits in usually with the arrows down the way, or if there is a triangular "angle" sitting, its how the caps fit into the sides - sometimes Electrolux/Eureka models have different caps on either side of the brush that need to be aligned properly as well as ensuring that the brush belt is on. Also check that the brush bar is completely clean. Hope that helps you!
Dec 26, 2008 | Vacuums
MY EUREKA WORLD VAC ROLLERS ARE NOT SPINNING. THE LIGHT IS ALSO BURNED OUT. IS THERE A CONNECTION BETWEEN THESE TWO EVENTS?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=813214
Generic problem for all Vacuums
Posted by agreene1038 on July 21, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Some of the Eureka brushrolls have a sensor in the brushroll that indicates that the brush is moving and the sensor and the light are linked together – you may have a bad brushroll – to check that you need to remove the brushroll, stand it on end and spin it freely, if it does not spin the bearings could be bad or needs to be replaced with a new brushroll and a new belt. The belt change is every 4 to 6 months for the best cleaning. . If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 21, 2008 | Vacuums
Eureka Toolbox 1040A Canister Vacuum Logo
32 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
