Question about Sony Handycam DCR-TRV740 Digital Camcorder
The sound is not working when trying to record on a new tape or do a new recording, but works on other tapes that have been previously recorded
    Scholar:
  • 130 Answers
There are 2 heads in the recorder. One for reading (playing) and the other for writing (recording). 1st try cleaning these heads
using a Squab (Q tip) with a alcohol based cleaning solution (Radio Shack). Always rub the squab on the head in the direction the tape would follow, not perpendicular.
Posted on Jul 31, 2009
5 Suggested Answers
larry james
  • 287 Answers
SOURCE: Sound
if it has a external mic jack you could see if that is working. if it is then the mic on the camcorder is bad.
Posted on Sep 16, 2007
  • 19 Answers
SOURCE: GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Posted on Dec 21, 2007
SOURCE: sony video camera will not record but will play previous taped t
TO REPLACE THE CCD ASSEMBLY. SOME MODELS ARE COVERED BY SONY WARRANTY EVEN AFTER WARRANTY PERIOD, BECOUSE OF FACTORY FAULTY CCD-S -ASK A SONY REPAIR CENTRE OR LOGIN TO THEIR WESITE GOOD LUCK: KOPASZ
Posted on Apr 21, 2009
SOURCE: No picture when trying to record
Check the following link. Call them and explain the symptoms and they should send shipping label to you so you can send the camcorder in for repair. I had my TRV38 repaired in about 2 weeks. Good luck.
esupport.sony.com/perl/news-item.pl?mdl=DCRTRV19&news_id=95
this is a known issue with Sony
Posted on Jun 09, 2009
Taped sounds are deteriorating and disappearing.
If the tapes you are using are indeed brand new, then I would assume that the heads on the tape recorder are either very dirty or damaged. Try using a q-tip dipped in alcohol to clean the heads of the recorder. Clean the rollers too and pins that guide the tape. If that doesn't work it may be a component problem. And may be cheaper to replace than repair.
Feb 10, 2009 | Dictaphone 1243 Handheld Cassette Voice...
Not recording or playing back recorded tapes
first leave your camcorder with the cassete draw open in a warm room for 24 hrs.
then, use a brand new cassette & re try.
if you get the condensation message, it means the unit has detected moisture on the heads, the unit will not operate... hence your problems.
May 09, 2017 | Sony Handycam DCR-HC14E Mini DV Digital...
Bad recording from any source
The fact that both inputs give you a bad recording indicates its something common to both inputs. First thing I would do is try cleaning the heads. It's the cheapest solution to try. There is also an erase head as well, but that is usually not part of the video head. The erase head erases the tape just prior to the record head recording the new material on the tape. Problems in the erase head will cause you to see both what you just recorded and what was previously on the tape. The picture will be distorted and shifting back and forth between the new program and the previous one.
- Jim
Nov 29, 2007 | Mitsubishi HS-U560 VHS VCR
Recording problem on Sony SLV-R1000
The deck needs a good cleaning. Try using a brand new tape and run it on playback for 20 min or so. You could try using a cleaning tape, but many of them are abrasive. If this doesn't work, you need a deck re-alignment which will cost more than your set is worth.
Nov 13, 2007 | Sony SLV-R1000 S-VHS VCR
Canon zr100 digital video camcorder won't record or show picture on screen
PLEASE USE MINI DV HEAD CLEANING CASSETTE & TRY , MAY SOLVE YOUR PROBLEM
Oct 20, 2007 | Canon ZR100 Mini DV Digital Camcorder
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Sound
Sep 15, 2007 | Panasonic VHS-C PV-L354 Camcorder
VHS Recording Tape
not much of a help but sounds like your record head is bad on the vhs heads,
use cleaning tape try that, if that fixes great, if it helps but not fully there, you might have to clean them by hand with very soft paper town and rubbing alcohol rub side to side very easy , if none of the above work you have a bad record head or record board, not worth repair vs cost
good luck
Aug 25, 2007 | Philips Magnavox 20MC4304 20 in....
Sony Handycam DCR-TRV740 Digital Camcorder Logo
75 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
