Question about Orange 10097 22oz DESOLVIT ALLPURPOSE - ORANGE SOL HOUSEHOLD PRODUCTS INC
Remove sticky labels from glass - Orange 10097 22oz DESOLVIT ALLPURPOSE - ORANGE SOL HOUSEHOLD PRODUCTS INC
    Problem Solver:
  • 11 Answers
Use rubbing alcohol. It works great
Posted on Jul 31, 2009
How do I install a tram 1191 ******* glass mount antenna
Has the sticky pad been used already? If not just remove it an place against glass an attach other side to glass as well. Making sure all parts have room. If sticky pad is removed or used up you can contact factory about replacement ot try thr rear view mirror glue that is used for those. The antenna works nicely when set up properly
Aug 21, 2014 | Tram 1191 Amateur Dual-Band Glass Mount...
How do I remove the sticky residue from a label placed on the outside of my new refrigerator without damaging the finish?
Soak a cotton ball with WD-40 (or equivalent) and apply it to the sticky residue area. Allow it to penetrate for a couple of minutes. Then gently wipe the area with that same cotton ball until it loosens and picks up the adhesive residue. Once that's done, simply cleanse the treated area with any dishwashing liquid or similar. Rinse and wipe dry.
May 02, 2014 | Kenmore 57029 Side by Side Refrigerator
Remove sticky label
Try rubbing peanut butter on it. It works great on glass jar labels so it might work for plastic as well.
Sep 02, 2012 | Health & Beauty
Dymo Twin Turbo has sticky label jammed in feeder out of sight. How do I get it out?
See here for detailed instructions on how to remove a label that has jammed inside a dymo labelwriter:
How to remove jammed label from Dymo Labelwriter
Sep 30, 2011 | Dymo LabelWriter Thermal Printer
I am trying to replace the front brake rotors on a 1999 volkswagen passat but need the chassis #. I have been unable to find this......where is it?
in 3 places.
1.in the trunk,a sticky label 3" square top line...
2.under the hood/bottom of the wiper panel,left of centre,in front of the air vent trough,stamped on metal.
3.under the windscreen glass,clear glass panel.
May 11, 2010 | 1999 Volkswagen Passat
Maytag refrigerators mtbe1956de liquids have dripped on to the bottom glass shelf and seeped under the edges where it cannot be cleaned. do I have to remove the vegetable drawers and totally dismantle the...
brute force on the glass shelf.... it was just stuck in place by the cold sticky liquid that had seeped under the edges and bonded the glass and plastic together
Jan 12, 2010 | Refrigerators
I've got a sheet of sticky labels stuck in the printer
Yuck! You will have to remove the pritner cartridge and carefully remove each one. Sounds like your print settings was not set to print labels.
Jan 29, 2009 | Brother HL 1250 Laser Printer
Sticky label
I assume the label is stuck under the platen
the easiest way is to get a rag, wider than the label, dampen it with some solvent, and try to roll it in like a piece of paper. don't use too much solvent, or it will run off into the machine. be careful, it may melt the plastic.
to see if you have a good solvent, stick a label on something it won't hurt, put a little solvent on the label, wait a little bit and see if the label comes off easily.
if you're not careful, you can damage the machine.
or take the machine to a repair shop, the platen is not easy to remove
Nov 20, 2008 | Office Equipment & Supplies
Remove sticky label from paper guide
depends on what kind of machine, they are all a little different.
Orange 10097 22oz DESOLVIT ALLPURPOSE - ORANGE SOL HOUSEHOLD PRODUCTS INC Logo
51 people viewed this question
Top Orange Home Experts
john h
Tom Chichester
Are you an Orange Home Expert? Answer questions, earn points and help others
