Drills Logo
Peter Lang Posted on Mar 17, 2018
Drill holder sleeve
To suit martek drill sharpener
1helpful
2answers
I have a Hitachi WH 18 DFL cordless impact driver, which I love. I was doing a little bit of heavy drilling, and now the drill bit is stuck. The sleeve extends as if to release the bit, but the bit do
My guess is that the bit twisted a little in the bit holder so the steel ball is bound. If the collar moves you could try a slide puller on the bit and see if you can impact it out with the slide puller. Or you could take the bit holder apart. There is a retaining ring that holds it all together right on top. Pull that off and a washer, spring and the collar will come off. Becarefull to watch for the steel balls on the spindle. They WILL fall out! Now hopefully the bit will come out. If not it may need to be twisted in the oposite direction that it got stuck when you were using it to break it free. Hope that helps and good luck!
3/8 Drill Driver, chuck replacement.
hi friend,
Step 1. Determine what kind of replacement drill chuck you want - a keyed chuck or key less chuck. Over the years, key less chucks have been widely used for handheld power tool drills, due to their improving grip torque and convenience.
Step 2. If you prefer replacement key less chucks, then you have to know what type of key less chuck you will need - a single sleeve key less chuck or a double-sleeve chuck. You can simply determine it by checking your current chuck. If your current chuck is a keyed chuck or a double sleeve chuck, then you will need a replacement double-sleeve key less chuck. On the other hand, if your current chuck is a single sleeve chuck, then you should get a replacement single sleeve chuck.
Step 3. Confirm the threaded mount size (spindle size) on the chuck. 3/8"-24 threaded mount for 3/8" capacity drill chucks and 1/2"-20 threaded mount for 1/2" capacity drill chucks, but there are some exceptions where just the opposite may occur. To be safe, always check the threaded mount before you buy replacement drill chucks.
hope this helps u
please rate me.........................
thank u for using fixya
regards
sivaranjini
21helpful
2answers
Black & Decker model 4300 manual
Here's a link to a downloadable .pdf manual for your sharpener that will give you pages and pages of instructions to make those dull bits history.
Enjoy!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 14, 2009 • Drills
Drill doctor won't sharpen bit
sounds like the angles have been cut wrong on the bits or you are drilling too fast
Keyless chuck question
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
Top Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
