Question about Avanti WCR683DZD Stainless Steel Wine Cooler
No power, lights or anything
Believe the circuit board went out. Is it worth tracking down a replacement?
This is easy. It's the power supply problem. I bet you there is no juice coming out of the same electrical plug. So fix the plug or reset the circuit breaker.
Posted on Dec 16, 2009
Suddenly went black w/o sound while watching. can't bring it back.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 28, 2016 | Televison & Video
While watching went to green horizontal green squiggles lines. cut off let cool down. cut on worked 6 wks. cut off cool down worked 2 days. cut off cool down worked 1 hour.
May 02, 2016 | Televison & Video
I have a samsung un39fh5000fxza the picture went dark while watching the other night ...I see no menu screen while doing the flashlight test and no lights thru the vents is it worth fixing & cost
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name and type of your device, in the search box [at the top right] of the display window; to gather down all the posts related to your device brand. It will make surf easy.
Jul 13, 2015 | Samsung Televison & Video
Attic fan falure hed light blinking furnace wont run
Sounds like the circuit board needs to be replaced. The exact same thing happened on my house furnace. Power went to the board, producing the flashing led, but stopped there. I believe this is what you mean?
Replace the circuit board.
Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Dec 04, 2013 | Coleman Heating & Cooling
Hi...recently purchased a 2005 Roadtrek RV with a Dometic RM 2354 fridge in it...was getting things ready for camping and had the RV hooked up to 110 power...pushed on button for fridge and went through...
You said there was NO lights on the unit. The Dometic service manual says:
1. No operation - no panel lights: DC Volts
Fuse
Wiring
Upper Circuit Board
Lower Circuit Board
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
I would start with the DC volatage and track it back until you lose it. Most of the time it does end up being the lower circuit board though.
Aug 03, 2011 | Dometic RM2652 Refrigerator
No power (dead after a lightning storm hit the house. Tried replacing the two power circuit boards and have a current going in and all around all circuit boards. Still no sign of life when plugged in...
If its after a lightning storm, it really could be anything. Your mainboard could quite possibly be shot. In fact almost anything in the TV could be damaged by a big surge. It could even be that your backlights went out from the surge too.
Does your power LED come on? What is it connected to? Directly to the power board or is it connected to the mainboard? If you have current through all the circuit boards, you may have a burnt tuner or chip on the mainboard.
Might not be worth fixing depending on the size/model. If its a big LCD, you could probably get a good deal on a working one of the same size with a broken LCD panel (~$100). Then you can just replace the broken LCD panel with yours and you have a fixed TV.
Aug 15, 2009 | Panasonic Televison & Video
Sylvania Lcd 32 in.
Is it under warranty by chance?
What is happening is when you turn on the TV, it's trying to power up the screen at that moment. If it can't power up the screen, it will turn off automatically. This is what they call, "Protection Mode".
All the TVs made by Funai (Emerson and Sylvania) are having the same problem. The Inverter Transformers needed to power up the screen are somewhat low quality and burn out easily. I'm sure of of them burned out.
Your TV, I believe, takes 6 of those things to power the screen. And they are all on one circuit board.
If the TV is not under warranty, then let me know what the board number is on that circuit board. The board inside the TV should have maybe 6 connectors that hook up the screen. I may be able to track down a replacement board for you.
Apr 25, 2009 | Sylvania LC320SS8 32 in. LCD Television
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
6 yrs old went dead
try unplugging the green CRT circuit board making sure the board isnt touching anything then try powering up the set. If it doesnt shut down the green crt is shorted. about 350 for a new tube.
Mar 11, 2008 | Sony KP-57HW40 57" Rear Projection...
Hood slide controls
switches and slide control for speedlook integral from the circuit diagram. it is worth while getting the printed circuit board out and looking to see if the track is blown. if so this can ofted be repaired by soldering wire links over the damaged part of the track
Apr 16, 2007 | Broan-NuTone K210A30 Kitchen Hood
Avanti WCR683DZD Stainless Steel Wine Cooler Logo
361 people viewed this question
Top Avanti Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Avanti Furniture Expert? Answer questions, earn points and help others
