Question about Daewoo 17N5 17 in.CRT Conventional Monitor
Monitor problems Daewoo 17" TFT LCDModel HL 710 S The monitor shows horizontal lines across screen where there is writing. It almost appears as if each line was lightly highlited right across the screen.In card games, a card will appear greyish as opposed to whit and reds appear almost flourescent. Co;our adjustment doesn't seem to change anything. I am working on an HP Pavillion 9870, Pentium IV and XP operating system. Regards, Bruce
    Top Expert:
  • Daewoo Master
  • 12,962 Answers
Try plugging in another known working monitor and see what happens. That will tell you whether the issue is with the monitor or your HP. And do not go to HP for assistance since they will not do squat for you - horrible support and not deserving of business.
Posted on May 02, 2017
5 Suggested Answers
  • 6966 Answers
SOURCE: No power in my Daewoo Monitor
Hi, Youo have zeroed in on the problem area. It looks like a power supply problem. More often than not, there is a fuse inside. If you would venture to open the unit up, do a visual check on the fuse. If it is busted: 1. Clean - no burnt/scorching/black marks inside the glass tube, then you can simply replace and hopefully the unit will be operational; 2. Dark smudges - or small burnt metal pellets inside the glass tube, then it is possible that you have other defective components that caused the fuse to blow. Normal components that are known to go bad are the big capacitor and or the power transistor regulator. Most current designs uses a switch mode power supply where your mains AC voltage is converted to DC that powers a circuit that eventually produces a lower DC voltage say 12VDC for use of the monitor. Should you venture a DIY (do-it-yourself), pls remember safety precautions when working with powered electronics. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Sep 26, 2007
  • 4 Answers
SOURCE: Daewoo L700C 17 in. Flat Panel LCD Monitor search here
Posted on Feb 10, 2009
  • 4 Answers
SOURCE: screen turns black
problem with the inverter chek it
  • 11361 Answers
SOURCE: daewoo w9zq 19"tft power light flashes but no screen :s
Open it up and check for bad caps in the power supply first, post back what you see so we can guide you further, see example of failed monitors due to bad caps:
Posted on Feb 12, 2010
Testimonial: "Worked a treat, you are the man budmrtn ;) Thank you very much."
Our three year ol Samsung TV has dark horizontal lines across the top of bottom of the screen. It is getting worse
Welcome to fixYa!
When you see lines like these across your LCD, it indicates a problem with your monitor's electrolytic capacitors.A faulty filter capacitor in the power supply board (SMPS board) can cause horizontal lines across your monitor screen.Horizontal screen lines are one of the most visible problems I see in LCD monitors & TV's that are 3-7 years old. It can happen as much from heat, humidity & less-than-ideal operating conditions, as it can from fluctuating current supply or manufacturing defects.
The way to repair horizontal screen lines is by removing the capacitors from the printed circuit board (PCB) and testing them with a LCR meter.
If it shows zero, there's your confirmation that the specific capacitor needs to be replaced.
now if you can replace them your welcome but i wont suggest that , cause you may break it more....!
any ways do comment if it helped you in any manner!
Apr 30, 2011 | Samsung HL-R6168W 61" HDTV
I use 17" TFT LCD monitor of HCL make. there is a blue straight line appears on my screen. please suggest what to do to resolve the problem.
change your screen resolutions two~three different settings and a different computer - lf the line appears in same position, it's most likely bad monitor.
Sep 22, 2010 | Computers & Internet
There is horizontal line come in TFT in last 2 yr i ask the dealer he told that its bcoz some resister short now after another line come in my TFT whats the problem? and notice that this problem come after...
You may have failing TFT (Thin Film Transistor, each pixel on the screen is driven by one transistor, so there are 100 of thousands on the LCD panel
) or bad connection or failing T-CON board.
See pictures here:
It will usually get worst with more lines as time goes by. New panel will be needed.
Jun 15, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Click the Menu button and use the '+' & '-' signs to select restore factory settings. Check if you get the same line in the BIOS screen, if so then you would need a replacement.
Nov 14, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
White horizontal line across screen
Upgrade the refresh rate to 100 Hz and downgrade resolution
Jun 23, 2009 | AOC CT720G 17" CRT Monitor
Horizontal black lines across the screen
you can try contacting Lumaco they are a British monitor repair specialist.
It might even be cheaper to buy a new one.
Jun 19, 2009 | Relisys TL 766 Monitor
LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
Problem with Interface board or panel.
Also maybe due to defective powersupply filters.
Dec 10, 2008 | LG Flatron L1710B 17" LCD Monitor
My screen has horizontal lines across it
its the ram
mine does the same took ram out replace
Nov 24, 2007 | Medion MD 7317 17" Flat Panel LCD Monitor
Daewoo 17N5 17 in.CRT Conventional Monitor Logo
48 people viewed this question
Top Daewoo Computers & Internet Experts
John Anderson
John Anderson
Michael Galve
Michael Galve
Saleem Baig
Saleem Baig
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
