Question about LG Kitchen Ranges
LG Range Model 30451ST; touchpad to control burners won't work, sometimes one burner works, other times no'; had $ 400 worth of repair, still same thing
jsrock516
  • 5911 Answers
SOURCE: Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Posted on Aug 04, 2007
SOURCE: gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Posted on Feb 19, 2008
jyackle5
  • 8197 Answers
SOURCE: Coverting a Vulcan 260L commercial range to Propane
Yes you can convert to LP gas. go to this web site to get the parts.
http://www.vulcanhart.com/manuals/F-30536.pdf
Go to page 9 and look at parts # 57 - 60 that is the part you need to change. You need to know the sea level that you are at though so you get the right part.
Now if you go to page 8 you will find where it goes part # 53 thru 61
To order the parts go to this web site
http://www.vulcanhart.com/parts.cfm
If any ? please fill free to ask.
Posted on Dec 17, 2008
freetek
  • 5568 Answers
SOURCE: Oven and broiler will not light.
You've probably done this by now since your message is May (makes us a May-December couple??) but wanted to write that the transformer that produces the park for ignition has failed.  I don't know how accessible it is in your unit, if you check on Sears website under Parts with your model # in hand, they could well have an illustrated breakdown of your range which would give you an idea of how difficult the replacement might be.
Posted on Dec 28, 2008
  • 1214 Answers
SOURCE: LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Posted on Jan 24, 2009
The touchpad on my Whirlpool range doesn't work
I think you must consult with the whirlpool workers
Dec 28, 2012 | Kitchen Ranges
My Whirlpool Gold Accubake, smooth top displays E1 - F1 (blinking). I am unable to utilize the oven because the push-button/ touchpad does not work however the electric burners work fine. Any clue? Many...
Hello, Thank You for using FixYa. I will be helping you today.This is erc or control failure. You would have to replace the electronic range control sometimes called the clock depending on your model number
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Whirlpool Ovens
My Kitchen Aid modelKGRC608LSS is not working on
Well it sounds like it is either the control key pad or the ERC(control module) is defective. The first thing you will need to verify is the condition of the ribbon cable that goes from the control pad to the ERC. You will need to unplug the range from the electrical outlet and then remove the back panel of the range. Now inspect the ribbon cable for any visible defects to it. Sometimes the cable will arc across itself and cause a short. Inspect each one of the lines(wires) on the ribbon cable and make sure they are not shorted. Now check to make sure the cable is found properly seated. If it is found loose or mis-aligned then remove and re-install it properly. You can also use a pencil eraser to clean the contacts on the ribbon cable while you have it dis-connected. Also verify that the wiring harness is properly seated and there is voltage going to the ERC. Hopefully these steps might get the range working again. The top burners/igniters can still work even if the touchpad or ERC is bad because they do not control the circuits for the igniters(they are mechanical switches) and mechanical burner valves. If not you might need to replace both the ERC and the Touchpad in combination to get the range to work again.
Apr 11, 2010 | KitchenAid KGRC608LSS Gas Kitchen Range
LG Range Touchpad Not Working
The touch mebrane is faulty and needs to be replaced.
Sep 03, 2009 | LG LRE30451 Electric Kitchen Range
Burners dont work all the time. Is it worth fixing?
replace element block clean(sand) ends of element(burner)yes it is worth fixing
Aug 15, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Maytag Electric Ceramic Glass top stove
You can replace the failed component which is either the burner or the switch that controls the burner. A voltage test would have to be done to determine which compoonent has failed. Generaally it is worthwhile to repair the range.
Apr 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Lg lre30451st right front/right rear burners won't come on
I tried this on the advice of another post. It worked for me and now all of my burners are working again!
Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile - be patient) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start"
Mar 15, 2009 | LG LRE30451ST Electric Kitchen Range
Jan 24, 2009 | LG 30 in Kitchen Series Dual Convection...
All my burners arnt working! HELP!!!
There is a cooktop PCB (power control board) which is separate from the oven. Perhaps that is the problem. That board is located behind the cooktop control membrane panel.
Oct 24, 2008 | LG LRE30755 Electric Kitchen Range
Kitchen Ranges Logo
Top LG Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Steven Clarke
Steven Clarke
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
