Question about Maytag Neptune MDG5500AW Gas Dryer
I have a maytag DE408 dryer that doesn't heat well
The dryer heats slightly when the timer is set to 50 minutes but does not get hot enough. It has to run through the 50 minute cyle twice. It will not heat on other settings.
  • 6,784 Answers
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Posted on Jul 31, 2009
I want to bypass timer, and have dryer turn on and off when I open and close the door, how do I do this. I am an electrician, but I am worried if I bypass the timer that I will bypass the door too.
Posted on Dec 17, 2009
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Dryer wont stop buzzing
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Hello, Yesterday my dryer stopped heating and the timer stopped advancing at the same time. Any suggestions?
If the timer doesn't advance on the auto, dry setting yet it advance on the timed dry setting regardlee if it heats or not the timer is fine and not advancing due to not heating and not problem with the timer. The not heating is probably going to a broken heat element it was the most common thing on the Maytag dryer from that Vintage of dryers. To check it UNPLUG DRYER remove front panel by removing the two phillips headed screws from the lower part of panel by that sligh step back in the panel.The heater will on the right side of the base frame in a tube.On the leftside of that tube will 2 wires that go into it remove those,3/8" socket to remove the brass nuts,use a ohm meter and place each lead on were those wires went and check for around 30-50 ohms,if the meter displays OL the heater is broke, This youtube vidoe will cover some of what i have already went over and show you how to remove and restring the heater,pause it at the 1:30 mark for a real good of when restringing how it is snaked through as shown the in video the part number is Y133538 it could be purchased at your local appliance parts store or on line at ;repairclinic.com assuredparts.com apdepot.com appliancepartspros.com
Good luck,i hope will help you to fix your dryer,
Gene
Aug 09, 2011 | Maytag MDE2706 Electric Dryer
I have a Maytag Legacy Electric Dryer Model MED5570tq0. It turns, gets heat, but does not dry the clothes. It would take 2-3 cycles to dry clothes. Any suggestions?
Hi jamesholl456...
Sounds like you have a Clogged Vent
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Cycling thermostat
This is a Free answer, Please rate me.
Apr 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
The Dryer has hot air but the clothes are not getting dry?
Clogged Vent
Heating Element
Cycling thermostat
Apr 14, 2011 | Maytag MDE6000 Dryer
Dryer does not heat up. Air dries, timer works, drum spins, but no heat.
Your heating element is bad go to a maytag or whirlpool servicer and get one for about $50. this will Fixya
Nov 08, 2010 | Maytag Dryers
Maytag centennial dryer - timer dial does not move - dryer is heating
You most likely have to replace the POS timer, my girlfriend\'s failed out of the box, a month later and again two years later. I dissected the timer and found the cheapest set of plastic reduction gears between the timer motor and the gear that drives the knob, and one of them had the teeth stripped off.
You can find them on ebay for less than $50 shipped rather than pay $100+ for one from a parts store.
Oct 11, 2010 | Maytag Dryers
Dryer element stays warm
If it heats w/ the timer in off position whenever plugged in the the element is shorting to ground, its most likely due to either a broken coil or a cracked insulator. If heating w/ timer set for drying but motor is not running, the heat circuit thru the centrifugal/start switch on the motor is stuck closed.
May 16, 2009 | Maytag MDE2600 Electric Dryer
Dryer heats &revolves but clothes do not dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
if this helps please vote me a fix ya
Jul 15, 2008 | Maytag Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
648 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
