Question about CTX S 500 (Beige) 15" LCD Monitor
Hiya. I have an old lcd monitor - CTX PV505
Hiya. I have an old lcd monitor - CTX PV505 i am having problems with my monitor going to unsupporetd mode when i try to play a couple of games which have been downloaded from Big Fish games. It plays the rest of them ok. I can hear the game in the background but no picture just the screen saying unsupported mode. what can i do to correct this??
4 Suggested Answers
SOURCE: Looking for AC power Adopter for CTX LCD monitor
Check it on Radio Shack maybe they got something
Posted on Jun 03, 2009
  • 152 Answers
SOURCE: Hi we have a ctx monitor PV720A that stays on for
glenn659, possible cause is bad internal switch-mode-power-supply" failure or SMPS is detecting something wrong with lcd cold-cathode-fluorescent-tube backlighting circuit, (INVERTER) and it goes into SHUTDOWN mode to try and prevent a catastrophic failure from occuring. Glenn, visit youtube, search for video clips on LCD monitor disassembly and also also research BAD Capacitors or Swollen Capacitors and also the "WHY DO LCD MONITORS FAIL PREMATURELY" Certainly your's will be in the top two causes! Did you do the flashlight test with your monitor "on" and connected to a known good PC with the WIN-desktop screen showing. Even though screen is BLACK it might still show the desktop when you hold the light about 1" from screen. Some will, some won't depends on condition of the power supply. In any case get back to me with your plan of action you intend to take after viewing YOUTUBE stuff. Bye for now. I'm louie12fix on fixya or lmistyrel@aol.com
Posted on Oct 02, 2009
  • 32 Answers
SOURCE: ctx monitor
try lowering the screen resolution
Posted on Oct 20, 2009
Faulty monitor ctx pv720a. The screen has the
Try another cable, or check the plug for bent pins. If they are all good, check that the monitor is set for VGA input (if it supports VGA and DVI) as it may be looking for a different input. Then replace the monitor. It's not common, but video processing circuitry can sometimes fail, and yours may have. New 17-inch LCD monitors are quite inexpensive now, so it would probably be more economical to replace this one than to try repairing it.
Jan 01, 2011 | CTX PV 720 17" LCD Monitor
Set up pv505 monitor to computor do i use both power dc in and display in put ports
Yes you do, connect the mains power to the monitor and the video cable from the monitor to the video port on the computer.
Sep 02, 2010 | CTX Value VL 510 15" CRT Monitor
Ctx pv720a monitor goes blank
This is what inverter board looks like:
http://www.shopjimmy.com/catalogsearch/result/?q=CTX%20PV720
Look for bad caps also, more likely to need new inverter board, warning, you can have bad lamp assembly also.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 27, 2010 | CTX PV 720 17" LCD Monitor
I'm missing the power adapter for the CTX Monitor S500. Where can I find one?
http://www.google.com/#hl=en&source=hp&q=power+adapter+for+the+CTX+Monitor+S500&btnG=Google+Search&aq=f&aqi=&aql=&oq=&gs_rfai=&fp=ff274912d96214e6
Jun 24, 2010 | CTX S500BA (Black) 15 in. Flat Panel LCD...
Black line over entire width of ctx monitor screen 1mm depth in mid screen.
You need a new screen surface...you can order one from any reputable dealer....just take your monitor apart and unattach all of the components and replace the screen area with the appropriate part. You are not specifying whether or not it's an LCD or a CRT...if it's a CRT just go buy a new one :) if it's an LCD you can replace the screen for 100 dollars or so.
Dec 15, 2009 | CTX Computers & Internet
I have a ctx moniter says undectected mode
CTX 15"1024x768 TFT LCD-Black Monitor · i have a ctx moniter says ... Answer. i have a ctx moniter and wen i plugnitin to pc tower itsays undeceted mode watdoes this mean. Close Close. ASUS Eee PC 1000H
Dec 03, 2009 | CTX 15"1024x768 TFT LCD-Black Monitor
Ctx monitor
Oct 19, 2009 | CTX S762A 17" LCD Monitor
Jun 03, 2009 | CTX SV900MD 19" LCD Monitor
CTX P772 17" LCD Monitor Problem
This is caused by sending a video signal to the screen at a refresh rate higher than 60hz. A LCD Doesn't refresh the image by scanning from top to bottom like a traditional CRT or picture tube. They are hard set to 60hz and can not understand anything else. Setting it to anything else will cause it to not display a video signal, picture tearing (little blocks with horizontal movement), Offset video or convergents issues (colors appear offset giving it the 3d movie look with out glasses on)
To fix it you need to go into your operating systems display settings and pick out a LCD monitor with a refresh rate of 60hz
Hope that helps
May 12, 2008 | CTX P772 17" LCD Monitor
CTX lcd monitor model s700b is come on 1 second and shut off
this purely the problem with operating system just reinstall windows... u will get rid of it...
ur monitor is in good condition no need to worry about that...
Jan 29, 2008 | Computers & Internet
CTX S 500 (Beige) 15" LCD Monitor Logo
99 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
