Question about Cycling
Twist grip shifter too hard to get into first gear
  • 162 Answers
Cables too tight
Posted on Jul 31, 2009
21 speed shimano grip shifters very hard to twist, how can I make them easier to operate?…thanks
This YouTube video tells you how to lube the shifters, seems to be well rated: How To Clean Lube Grip Shift Shifters
You should also check cable/housing, however, as if they are corroded, kinked, etc. the shifters will also be hard to operate. Do not use grease to lubricate cables, though - only a light oil or spray lubricant. You can also just replace the cables.
Sep 09, 2017 | Shimano Cycling
Grip shift 30 will not hold
Either gear cable is too tight or shifter is worn. Has cable been recently adjusted? if so, it needs to be readjusted. More likely, the shifter is worn so that the cogs aren't grabbing the tooth for high gear. It may just need to be cleaned or replaced. A good how-to website is "sheltonbrown.com". Your local bike shop can also assist
Oct 19, 2014 | bike.com PDW Dapper Dan Lock On Standard...
Rear derailler will not click and hold shifted gear
Sounds like the internal spring that indexes the shifter is either broken or missing. I believe these bikes came with twist shifters. Those springs are hard to find nowadays and it's just as inexpensive to replace. Your local bicycle shop should be able to find a suitable replacement shifter for your bicycle.
Apr 02, 2014 | Roadmaster Granite Peak 24" Girls Mountain...
How do I remove a grip or twist shifter to replace it with a new one?
You plug this "how do I remove a grip or twist shifter " into a search engine.
Aug 18, 2011 | Cycling
When changing gear it returns to sixth gear , (twist grip gears) 6 gear 20in boys bike
If you're saying the shifter itself isn't staying in the selected position and is always relaxing ALL cable tension, you have a defective shifter. Some, like the Grip Shift MRX, seem to rely on the handlebar grip to keep all the guts inside. I know of one where a space developed when the grip slipped outboard a little bit and the shifter parts separated enough for a key piece to fall out.
No one sells the nickel part so you'll probably end up replacing the whole shifter. You may even have to buy a complete set. If you have to go that far and it IS a defective design I'd get a Shimano shifter that works with 6-speeds. Like Revo. Look on eBay.
OR, maybe the cable is just really loose.
This resource is very useful...
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Jun 15, 2011 | Cycling
Yes i just bought a short throw shifter for my 2003 alero but i cant find out how to swap out because there is a plastic O ring around the factory shifter that i just cant remove.
I have a 2000 Alero Gx coupe.. Same setup. I had to use some sort of plyers, Grip the stock rubber shift knob, and twist to the left as hard as I could to get it unstuck, then set plyers aside, and unscrewed with my two fingers. Once off, that safety feature and spring slids right off. you can use it with a custom knob, unless you are cutting it down to make a short shifter (Or a short-shifter kit, either way works)
Hope this helps :)
Nov 27, 2010 | 2003 Oldsmobile Alero
Need to adjust the front derailer, it won't change gears
There are two small screws which control the travel limits for derailer systems. Normally located top left of front mechanism when viewed from side. Adjust to allow travel within limits of gearing. Make sure that cable is not slack when in low gear position.
Jun 10, 2009 | Mongoose Exile 26 Men's Full-Suspension...
GRIP SHIFTERS WILL NOT TWIST WHILE TRYING TO SHIFT
This is likely because either a) the cable leading from the shifter to the part you are pulling is seized or b) the shifter itself is seized or c) both are seized. You would have to undo the cable from the rear deraileur, pull the inside cable out from the casing from top to bottom. Check it and see if it is rusted or full of crud. Give it a cleaning and spray some light lube down the outer (black) cables, then reinsert the cable. While the cable is undone, it wouldn't hurt to see if you can twist the grip shifters. If they are still tight, then get some lube in the grip shift. Also make sure the rubber grips are not too tight against the shifter. Hope that helps...
Mar 23, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
Vespa Operating Manual
The gears seem odd to people at first but are actually very easy to master. For first, pull in the clutch (left lever) and twist the entire grip back (towards you). Release the clutch and bingo. For second, third and fourth pull the clutch and twist the grip forwards one step at a time. If you look at the left handlebar you'll see the little numbers and a mark on the main headset. If these don't line up you might need to get your shifter cables tightened and lined up.
Feb 01, 2009 | Peg Perego Vespa Scooter
Cycling Logo
377 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
