Drills Logo
John Wharton Posted on Mar 17, 2018
I am not sure how to remove the brushes on a Metarbo KHE32 hammer drill i have been given, can you help me please?
Got it, I just prised them out from the back!!!
5 Related Answers
Anonymous
  • 2712 Answers
  • Posted on Aug 27, 2008
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Anonymous
  • Posted on Mar 27, 2009
SOURCE: Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
peter evan
  • 103 Answers
  • Posted on Apr 12, 2009
SOURCE: Ryobi cordless drill burning smell
your over using the drill on havy jobs
Anonymous
  • 154 Answers
  • Posted on Apr 13, 2009
SOURCE: Bosch 11247 Hammer drill works
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Anonymous
  • Posted on Feb 26, 2010
SOURCE: I have an AEG hammer drill that no longer hammers.
service manuals AEG SB2E-1001
HAMMER DRILL . bosch bulldog extreme max hammer sparking BAD and electrical burn smell? How do I get the part that houses the brushes out?
It sounds like the issue with your Bosch bulldog extreme max hammer is likely due to worn out or damaged brushes. Here are the steps to remove and replace the brushes:
  1. Unplug the hammer drill from the power source.
  2. Remove the two screws on the top of the hammer drill handle with a screwdriver.
  3. Lift off the top of the handle to expose the motor.
  4. Locate the brush holders on either side of the motor.
  5. Gently pull out the brush holder on one side of the motor.
  6. Remove the brush from the holder by gently pulling it straight out.
  7. Repeat for the other side of the motor.
  8. Inspect the brushes for damage, wear, or discoloration. Blackening of the brushes is normal, but if they are excessively worn or damaged, they should be replaced.
  9. Insert the new brushes into the brush holders, making sure they are properly seated.
  10. Replace the brush holder on one side of the motor, then the other.
  11. Reattach the top of the handle and replace the screws.
Regarding the digs in the motor surface, if they are not too deep and do not appear to affect the operation of the motor, they may not need to be addressed. However, if they are deep or if they appear to be affecting the motor's performance, it may be necessary to replace the motor.
It's important to note that working on power tools can be dangerous and should only be attempted by those with the necessary knowledge and experience. If you're unsure about any step in the process, it's best to seek the help of a professional.
2answers
How do you install brushes on a 5370 hammer drill
If they are replaceable, you will be opening up the drill by removing the screws holding it together, and then you might see the brushes that need replacement.
Know that although you can open most hammer drills, and you can replace the brushes in some, some you cannot reassemble, but you can surely try.
I fix these myself, and my success rate is about 50 %.
God bless your efforts.
1helpful
Hi dear I need one regalator for hilti te75 or te1000,Wher can I finding that one.Please help me .Thankyou
any good electronic shop should be able to assist are you sure its the regulator and not needing new brushes as hilti,s are prone for the brushes wearing out
1helpful
Hello - could you help me source replacement carbon brushes and brush holders for this hammer drill please ?
Carbon brushes by a hammer drill is in most cases acomplete service job , because of the working hours that is have it behind but a consumables kit and lubrication can doing wonders.
If rotating hammer it should not and it will not take too long before it must replaced before it started damage in a short time.
1helpful
SbE505 hammer drill needs new brushes. How do you remove hammer/drill ring switch behind chuck to take drill apart?
You shouldn't have to take the tool that far apart. Just remove the screws that hold the switch handle together, remove the handle, and you should see the brushes. The brushes are at the rear of the tool, not the front.
2helpful
How to change brushes
on the BHP451 there are 2 screws on the back cover that need to be removed and then you can access the brushes and on the BTD 140 the same is true. The part number I see is 194427-5. If I have helped in answering your question would you please vote accordingly and thank you.
How to dismantle a makita HP electrical hammer drill, want to replace the brushes
Check out the split drawing on this page.
If your makita does not have any outside accessible brush caps, you need to dismantle it.
lay it on the side, where the side with the screws securing the to halves together is facing up.
Remove all screws (some may be hidden under labels etc.) Gently pry the halves apart, locate the brushes disconnect their leads if any, and remove. Install new brushes and make sure the move freely, and that they are springloaded when in place. Gently rotate the rotor to ensure everything is ok . Reassemble and test drill. If the brushes leaves long streaks of noticeably large sparks, something has gone wrong or the rotor was damaged in the first place, causing excessive wear.
Dewalt cordless drill dc988- drill motor works intermitantly when trigger is pulled. Works a little better as it warms up. Im thinking vsr switch, brushes, or motor/armature. please help...
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
2answers
I have the same problem. 1199VSR hammer drill. The tool is 18 months old (out of warranty) and has barely been used - I think I used it for for two jobs - all together about 12 1/2" diameter holes. It...
Check the motor brushes for breakage, badly worn, or weak springs (heat damage). Keep track of brush wear pattern when removing and reinstall in the same orientation.
2helpful
2answers
Rotary hammer won't rotate, hammers very good
Unscrew the brushes and take a look at them. It sounds like you need new brushes.
Apr 06, 2009 • Drills
Top Hammer Drills Experts
john h
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Hammer Drill Expert? Answer questions, earn points and help others
