You believe you can fix the jack, but you can't work-out how to open the box it's in.????
Most boxes will have 2,3 or 4 small screws which secure the outside body together.
Sometimes the screw heads are obvious, sometimes they are concealed behind blanking plugs which will need to be pried-out & sometimes they're hidden behind a manufacturers label.
Some boxes are welded shut, so you'll need to brake open the welds on the seams. If it's already useless, you won't make it any worse by trying to open it, but do it slowly & you MIGHT get away with it.
Best of luck
SOURCE: Battery Recharge
"Removable drive" sounds like it got set back to MTC mode (USB mode in sansa settings menu). Needs to be in MTP mode to really be of any use. I have the e280 and it recharges fine when it's hooked up to my PC. It might be the battery, the connection, or the player. Also, it has to be a "high power" USB port on your PC (whatever that is). ie: If you're on a really old PC, there might not be enough juice getting through to the player. But if the rechargers don't work either.....
SOURCE: MY BLUE TOOTH ISN'T BEING READ BY MY PHONE...
Delete the headset from your phones previous or known devices and turn off phone then back on again and try pairing again. If still same could be faulty phone, but if you can try headset on somebody elses phone to rule out headset.
SOURCE: blue tooth device is not working
hi,
check if your device is enabled, you can do this by ---
right click my computer..-> properties--> hardware tab--> device manager --> right click on the blue tooth icon and clcik properties. --> check if enabled..
if it is enabled check if bluetooth is enabled at startup { type msconfig in RUN in start menu, click startup tab..check if it is enbaled in startup}... or else you have to manually switch on bluetooth each time u intend to use... hope it helps.
hope to get rated as helpful...
regards
bzoy
SOURCE: acer aspire 3680-2022 sound output & blue tooth
Hi
Please load driver from acer.com it will work...
Thanks
SOURCE: Please could you obtain Logitech Rechargeable Speaker manual
http://www.retrevo.com/s/Logitech-S315i-Speakers-review-manual/id/23582ci761/t/1-2/
Click on the "Manuals" tab, then the "Get Manual" button.
