Question about LG Vu CU920 Cellular Phone
Charging problems with lg vu
Have had charge port replaced under warranty repair by lg. still having issues charging it. it will only charge with data cable connected to laptop now.
Lgcu920 not charging jack change but no chargingplz problem solved
Posted on Jul 01, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 44 Answers
I am getting "this cable is not recommended for this phone" and it it he original cable and charger ( 2 of them )
one cable went 2 months ago, so it may be the cables and not the charging port....
Posted on Feb 09, 2010
Phone won't charge or hold a charge - tried 3 different chargers and a new battery. Cleaned all connection points with alcohol. LG Vue
The problem with the phone is the charging port since you have use different charger and you have even change the battery and yet not still charging. it means the charging port of your phone is the problem.
All you need to do i to replace the charging port on your phone and you will see that your phone will charge.
Replace the charging port on your phone and your phone will start to charge, just change the charging and the problem is solved.
Take care.
Jun 02, 2010 | LG Vu CU920 Cellular Phone
Will not turn on
The most common problem I see with this model phone is the charging port breaks in them. Look in the port on the phone and see if it is damaged. Usually the ends of the port (last pin on each end) break first. The last pin on each end are both grounds for the charging system. If they are broke then the port will have to be replaced. Replacing requires special equipment, so you will have to contact your local repair shop. The company I work for charges around $40, so it should cost somewhere around there.
Dec 10, 2009 | LG Vu CU920 Cellular Phone
My LG Vu shuts off automatically after about a couple of hours
your phone would be under warranty period. get it repaired/replaced from the service center
Aug 01, 2009 | LG Vu CU920 Cellular Phone
It wpnt charge unless i put the charge a certain way
yes i have had same problen i took phone to store and they put a new charge port in it
Jul 18, 2009 | LG Vu CU920 Cellular Phone
The battery dies so fast
DramaQueen-
You charging port is probably going bad. It happens now and then.
Contact your provider if the phone is still under warranty.
If not check out the following link for solutions to the problem.
Problem With LG VU Not Charging
Jul 15, 2009 | LG Vu CU920 Cellular Phone
My lg vu will not charge
There are 2 possible problems you are having. You charger is going bad as evidenced by th cable going bad. Take it to a carriers store and try a different charger.
The other issue may be the charging port is going bad. Having to tape the charger may be an indication of that.
Try a different charger first but if that is not the problem check out the following link for ways to fix the charge port on your LG VU
LG VU Charge Port Repair
Jul 13, 2009 | LG Vu CU920 Cellular Phone
LG Vu Wont chrge correctly
Your charging port is probably going bad. It seems to happen fairly regulary on the lg VU
you can get it repaired or get a workaround external battery charger.
Check out the following link for your options.
http://www.chargemyphones.com/lg-vu-wont-charge/4/
Jul 02, 2009 | LG Vu Cellular Phone
Lg Vu wont charge
First you must determine is it the charger faulty or the phone ? , have you a friend with the same phone if so try her or his battery to see if your phone is ok if so try the charger with your battery and see if it charges if it does get a new charger , if it did not charge or work with your friends battery or charger the sorry it would be cheaper to buy a new phone than try to get it fixed ...
if you haven't got a friend with the same phone have a local electrician check if there is an output from your charger . if there is it may just be the battery try a new one if still no luck it is probably the phone's charger circuit gone pop ,, sorry .. vortash
May 13, 2009 | LG Vu CU920 Cellular Phone
Something is either work my my charger or the phone for the lg vu. a few days ago, the charger worked fine but for some reason its ot working but the red dot on the charger is on; when i plug it to my...
It is loose now the charging port may have gotten broken. It happens with the LG VU's.
If this is the case, you have 3 options.
1. repair -warranty preferably
2. new phone
3 or external battery charger. cheapest option
Check out the following link for more information
How to Charge LG Vu with Broken Charge Port
Mar 07, 2009 | LG Vu CU920 Cellular Phone
Battery charge
I agree that it sounds like you charger port is going bad.
The firststep is to contact your carrier to see if it is covered under warranty.If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.You can get an external battery charger to charger the battery separate from phone. cost about 25 dollars. Check out the following link for ones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
LG VU External Battery Charger Cradle
I hope that helps
Mar 01, 2009 | LG Vu CU920 Cellular Phone
LG Vu CU920 Cellular Phone Logo
875 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
