Question about Sharp AR-405 Printer
The problem I am having is this: The unit will not power on but I can hear a clicking sound coming from the back of the copier. And I can see an LED flashing on the main board but it will not come on. Belive it could be a sensor. It was working fine until I turned it off and then back on after having problem with the output carriage. After I corrected that it printed and outputted fine. Then when I turned if off and back on the power would not come on.
  • Michael Lynn Hacker Jul 31, 2009
    I was poking around in the copier but I could not see a relay, I have accessed the board from the back of the copier and noticed a red led blinking when I turn on the power and hear the clicking. If I try to unplug the power for 24hrs and this does not correct the problem. Where would the relay be? On the power supply or main board?
  • Michael Lynn Hacker Aug 05, 2009
    thank you very much I will try this and see if it works okay. How would I obtain repair manual for Sharp copiers?
    President:
  • 2,185 Answers
If you can see a led flashing, try pressing the stop/cancel and holding for a few seconds, like 10 minutes until the flashing stops.
Also, look for possible paper jam.
As for the sensor, tiny paper shreds might be blocking it so you might as well want to look at it too.
Posted on Aug 01, 2009
  • virtualhost
    virtualhost Aug 05, 2009
    Hello Mhacker,
    Just want to follow up if you were able to solve this problem?
  • virtualhost
    virtualhost Aug 24, 2009
    Hi again,
    Can I get the exact model of your copier?
  • 11,896 Answers
Could be faulty capacitor on the power supply or main board. It is usually the power supply. Try unplugging machine for 24 to reset itself and then try again. If you are hearing a clicking noise, it could be power supply or a relay if there is one in your unit.
Posted on Jul 31, 2009
Sony kdf-37h1000. push power button and the green lite comes on steady and i can hear a fan. never gets to a picture or sound. it then sounds like it shuts power off but lite goes from flashing green to...
Hi catfishbob,
You're lamp came to its peak burning life and now its dead that's why you can't power up the unit and the led light keeps flashing. Once the lamp replace with new one your unit will back to normal again. Click this link for the replacement http://shop.ebay.com/i.html?_nkw=KDF-37H1000&_sacat=0&_odkw=sylvania+ld370sc8s&_osacat=0&_trksid=p3286.c0.m270.l1313.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 05, 2011 | Sony KDF-37H1000 37" HDTV
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
TV won't turn on, red light flashes on TV and hear a clicking sound in back of unit is it worth fixing?
Yes,the LED power lite on the front panel stable?Yes,mean the DM power supply board is good.LED power like blinking,mean the DM power supply board is dead.DM power supply is good,still making that clicking sound,when turn on.Mean ur Blast board is dead,that the board that help to light up the projection lamp.
Jun 24, 2010 | Hitachi 43UWX10B 43" Rear Projection...
RCA 52" D52W20 ATC221 TV Problem
The FBT is dead.The buzzing sound mean there no high voltage is come to the CRT(tv tube).No burning,marks on the FBT doesn't mean it not dead.I change parts all the time with out burn marks on them.Trust me i replaced dozen of the FBT before.It make buzzing noise it dead.
Mar 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Kicker 250.2 amp, I have green power led, but the red led on top of the unit does not come on, nor does the red protection led, hear a click out of the subs on occation but nothing else, looked inside and...
Sometimes clicking, or popping sounds from subs are caused by over excursion of the subwoofer, wich can be caused by ultra low frequency, or going below the tuned frequency of your enclosure.
Aug 12, 2009 | Car Audio & Video
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
May 16, 2009 | Pioneer VSX-305 Receiver
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
gysgt2u1@yahoo
Mar 05, 2009 | Philips 50MF231D 50 in. Plasma Television
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
