Question about HP Officejet 5610 All-In-One InkJet Printer
Paper jam won't clear.
I have searched the printer for any left over paper and there is nothing in there. When I press OK, the cartridge moves and then it tells me I still have a paper jam. What to do? What to do?
  • 724 Answers
Also see if there is any debris between the gears
Posted on Aug 02, 2009
  • 108 Answers
Try to clean the feed rollers and see if that works.
Posted on Jul 31, 2009
Cartridge jammed
Error : Cartridge Jammed
Cause : The print head holder cannot move. This is normally due to a paper jam.
Action : Clear the paper jam or whatever is obstructing the print head holder. Reload the paper in the machine correctly and press [OK].
Hope this helps.
Have a good day.
Dec 04, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
Jamming problem
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
"Clear paper jam" error, but there is no jam!
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
May 25, 2017 | Epson Stylus Photo RX620 All-In-One InkJet...
There is a print cartridge crudle is stuck...clear jam and press ok saying on the screen of my printer what should i do?i cleared the paper jam but it still says the same thing
Remove your cartridges, pull the power out see if the cradle moves freely around by hand. Check make sure that theres no paper that stayed behind. Did you rmove the paper by force? Maybe you dmaged the paper sensor.
Dec 08, 2008 | HP Photosmart 8150 InkJet Printer
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP Photosmart 2610 - Paper Jam
I cleared the paper jam but i am still getting a paper jam message. I checked thoroughly and dont see any pieces of paper anywhere. I press ok and still get paper jam message. I turned the priner off and on serveral times and that did not work. Same message. I am feeling very frustrated. Its been a week today. Help!
Sep 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
150 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
