Question about Canon Office Equipment & Supplies
Have just put 2 new ink cartridge in printer, but can get no print on Nozzle check ? they seem to fit in printhead fine? can you help ?
  • spb170561 Jul 31, 2009
    have removed the seals, and there is nothing on the paper when i try to print...have done deep cleaning via maintance and nozzle check..
  • 149 Answers
It could be a silly one, such as the seal on the print cartridges been left on OR and most likely, the printhead maybe be blocked and need cleaning or replacing. Do you have any errors or any print on the paper at all?
Posted on Jul 31, 2009
There are no signs of error but the paper comes out blank
Hi Zanda
if you haven't used your printer for that long, your printhead is more than likely dried up and clogged. Try running the "Head cleaning" utility 2-3 then print a "Nozzle check" (find both of these functions on "Maintenance" page under "Printer properties".
If the nozzle check shows any print, you're on the right track. Run few more head cleans or try printing several pages (with LOT of colour) on high (best photo) quality. Combination of printing & nozzle checks works best. Be prepared to waste lot of ink doing this!
If you get no print at all, it's probably time to get a new printer. There are other things you can try eg. buy set of cleaning cartridges, try to clean the printhead by placing some folded tissue soaked with Windex under the printhead or forcing some Windex through the printhead pickup (using a syringe & rubber tubing fitted over the pickup needle - where the cartridge usually sits) etc.
Another way yet is to remove the printhead from printer and soak it in cleaning solution (if if you're handy and prepared to pull your printer apart).
good luck!
Lumir
www.inkbank.com.au
REFILLABLE CARTRIDGES
Mar 02, 2014 | Epson Stylus RX425 Multifunction...
Printer will not print text. will only print picutres and graphics and text on graphics. just replaced the black and white cartridge.
It sounds like you are either out of black ink or you have a clogged black printhead. Perform a nozzle check/test page, then do 3-4 printhead cleanings. Run another nozzle check/test page and compare it to the first one. If you see improvement, keep cleaning your printheads until the black printhead is unclogged. If you do not see any improvement, you may need to replace the black ink cartridge. (I am assuming that your printer uses a tri-color and black ink cartridge) Replacing the ink cartridge will give you a new printhead (attached to the ink cartridge).
Jul 05, 2010 | Computers & Internet
The 3ebk nozzle check shows problems and prinitng is blurred
First of all you take out your cartridge form printer and try to clean nozzle from tissue paper then insert the cartridge in your printer then take a print out. If it is still not working then you have change your cartridge.
Regards
Ashly
Feb 04, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Printer will only print in colour ink, not anything in black text
The issue your having is more then likely the ink cartridge itself or the printhead. Here is the steps in checking and possibly fixing the issue. Step 7 though should be done by a repair tech.
(1) Check that the orange cap or tap is not on the printhead.
(2) Remove the printhead and re-install it.
(3) Perform printhead cleaning, and visually check the test print for non-discharge of ink from nozzle.
(4) Perform head-refreshing, and visually check the test print for non-discharge of ink from nozzle.
(5) Replace the appropriate ink tank.
(6) Replace the printhead
(7) Replace the purge unit.
Jun 18, 2009 | Canon Office Equipment & Supplies
Kodak ESP-5 AiO says "0%" ink even after I install new cartridges
Let's clean and align.
Make sure that there are 5 - 10 sheets of plain paper loaded in the paper tray.
2 Press menu to display the main menu.
3 Press down arrow until Maintenance is selected.
4 As needed, press down arrow until the desired option is selected.
5 Press OK.
6 Follow the prompts in the display screen to initiate or cancel the task.
These available maintenance options are shown below:
Check Ink Levels
Nozzle Check
Printhead Alignment
Clean Printhead
Print Demo Sheet
Print Test Page
From windows, : Open the Home Center Help panel by clicking Help on the Home Center window, as needed. Click Maintenance, and then click
Nozzle Check or Printhead Alignment.
Macintosh: Open the Home Center window and click Maintenance, and then click Nozzle Correction or Printhead Alignment.
Should be good now.
Regards
Richard.
Apr 24, 2009 | Kodak ESP 5 Printer
Canon pixma mp780
Try uninstalling/reinstalling the drivers.
Is the error light flashing?
From the printer utility can you print a nozzle check sheet or align the printhead?
Does it seem to be printing (feeding sheet and moving printhead) or nothing happening at all?
Try removing all the tanks, take out the head. If blocked try cleaning manualy by running warm water over the ink ports/printhead jets - dry off and reinstall.
May 10, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Black ink
Please try the following to resolved the issue:
Run a series of head cleaning
1. Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START, CONTROL PANEL, PRINTER & FAXES then right click on CX3200 printer Icon then select printing preferences
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Mar 02, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Cannot print Black on anything...
Your printer works with the PGI-5BK cartridge, that are in fact just ink-tanks, the printhead being apart of the tanks, so if the cartridges are not empty, it cannot be because of them. It doesnt matter if you replace the cartridge, the problem is in the printhead.
If the problem occured just a while ago, you should consider that NOT PRINTING a long time (30 days) with a printer can lead to ink drying out in the printhead, clogging the nozzles. OK, now it comes: If you have some tehnical skills, you can remove the cartridge and desassembly the printhead (where the cartridge are in) and do the following:
Put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the printhead with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridges back on the printhead (without installing it in the printer), rap it in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the printhead on some sheets of tissue.
Get the cartridges again out of the printhead, install it in the printer, then install the cartridges again and run a few cleaning processes from the printers maintenance software.
It should work. If you dont have the tehnicall skills needed, Canon gotcha, or you can visit a local specialist to make all this for you, they usualy have better equipmens, as ultrasonic cleaners and special solvents that makes all this easyer.
Rate the solution if it helped you!
Thx.
Feb 03, 2008 | Canon MX700 Office All-In-One InkJet...
Black will not print
I am not sure if this will help but I will try. I have 4 types of Canon printers and 7 canon printers. I have had problems w/some of my colors not coming out. There are 2 ways that I've done. First is the simpler one. Just go to the printer maintenance and choose nozzle cleaning for the BCI3 or the Colors CMYK or for all. If after that you do a print check, not the printhead alignment, and the black still doesn't come out then the 2nd way is to pump it out of the printhead. The print check should give you an indication which of the black is not coming out. I checked over the net and see the IP4000 has 2 black cartridges BCI3 and BCI6. So we need to identify which of the black is not coming out. Based on the print check you can identify which of the black is clogged. I suggest you remove the printhead from the printer. The lever that holds the printhead should be just above or in front of the cartridges. I'm guessing that you may have used refilled cartridges before. Which might have caused the clog. But then even original inks under extensive use also has that problem. Not as fast though. You can choose to identity which of the 2 black colors are clogged or you can choose to just unclog the 2 black colors in the printhead. You can do this by getting a syringe and a plastic or rubber tube that has about 5mm for the inner diameter hole. Cover the round nozzle from the inside of the printhead and slowly pump out the nozzle. You should have tissue or newspaper under the printhead and make sure it less than an inch above the tissue or paper. That way you don't get splattered when the ink comes out. When the old ink has cleared out, put the cartridge back in w/ the printhead. Turn the printer off and on a 2-3 times so the printer can prime the tubes in the printhead. Do either 2 light or 1 deep cleaning. Then do a printcheck to see if the black will print.
I think you problem is only a clogged printhead. So you can do the light nozzle cleaning,or deep nozzle cleaning or you can flush out the printhead manually. This should open it up and I think it will be ok. If not, let me know. That's going to be a challeng for me.
Oct 09, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
37 people viewed this question
old marine
old marine
