Question about Yahoo Messenger
Y!im has 81003004 error
Since sometimes this morning (CET) it hasn't connected and i have tried the steps suggested here :(
Also i have removed and reinstalled it... and switched off my firewall. Only when i try to install through the web installer it says it cant connect to the server...
  • 5,081 Answers
I am sure your computer has registry problems.It is very easy to repair 81003004 error. you just need 3 steps:
1: Download a registry cleaner and install it.
2: Open the registry cleaner and scan you computer for free
3: Click fix button and you done.
Download the top 81003004 error repair tool here: http://www.fixerrorfast.com/ttfix-810030… Source(s): http://www.fixerrorfast.com/ttfix-810030…
Messenger 9 for Vista users and XP users with 9, With windows new update to their FireWall, Has so many glitches. Yahoo has given up and no longer trying to fix it.http://www.ymessengerblog.com/blog/2008/… The updated Firewall will not let Messenger download correctly.And is causing 8.1 users to have major problems now. The only option they are leaving users with is reverting back to 8.0 or 7.5 these and all versions can be found here;http://www.filehippo.com/download_yahoo_… They are releasing a new version 10 (untested) as usual!
You need to remove version 9 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Posted on Jul 31, 2009
Yahoo error 81003004
sometime yahoo has a glitch or two from time to time
Jul 31, 2009 | Yahoo Messenger
My yahoo msgr shows error 81003004
error 81003004
what I do ??
Jul 27, 2009 | Yahoo Messenger
When I try to login to yahoo messenger I get error 81003004
hi,
Follow these methods:-
First method:
1. go to messenger menu
2. select connection preference/ preference
3. the tab will automatic select connection preference, if it doesn’t, select it manual.
4. change your internet conection type, for my problem i choose broadband(DSL/Cable).
Second Method
For me, it was because I had set a localhost (127.0.0.1) proxy in Internet Explorer for anti-filtering purposes, thru which Y! Messenger was trying to connect. So I had to remove it to get it done.
just go to:
Control Panel > Internet Options > Connections (tab) > Lan Settings (button)
then uncheck the Proxy server checkbox.
Thanks!
Jul 17, 2009 | Yahoo Messenger
Login error 81003004 from Yahoo Messenger
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection  Prefrences and use a http proxy.
thank you
Jun 02, 2009 | Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
It`s not work what happened ? 81003004
[Solution # 1]
(1) Check your firewall to be sure that this port is not blocked.
(2) Ensure that another program is not using the same port number.
Type netstat in command prompt to see all active ports.
[Solution # 2]
Goto Connection  Prefrences and use a http proxy. It helped!!!
[Solution # 3]
It might do this because it cant recognize the internet. Mine does this from time to time too, but I'm not sure if I get that particular error.
Try a couple things.
1. Totally close down Yahoo! and open it back up. See if that helps.
2. If you have a Wireless connection, shut your computer down and basically reboot the connection. Unplug your modem, then your router. Wait 15-30 seconds, then plug in your modem. Wait for the lights to all become solid, plug the router back in, then turn your computer on.
Sometimes a router will stop recognizing your computer. I've had it happen to me, and the odd part of it was I could still browse the net, but not use my IMs.
3. If nothing else works, uninstall and reinstall Yahoo! IM. It may just be a glitch.
[Solution # 4]
Take a look to this address : http://epayvn.info/2009/01/yahoo-messenger-error-81003004.html
Good luck
Apr 15, 2009 | Yahoo Messenger
Problem in logging in yahoo messenger
[Solution # 1]
[Solution # 2]
[Solution # 3]
[Solution # 4]
Good luck
Apr 03, 2009 | Yahoo Messenger
Not able to login thru yahoo messenger
[Solution # 1]
[Solution # 2]
[Solution # 3]
[Solution # 4]
Good luck
Mar 19, 2009 | Yahoo Messenger
Sign in problem 81003004
[Solution # 1]
[Solution # 2]
[Solution # 3]
[Solution # 4]
Good luck
Mar 14, 2009 | Yahoo Messenger
Error 81003004
[Solution # 1]
[Solution # 2]
[Solution # 3]
[Solution # 4]
Good luck
Mar 05, 2009 | Yahoo Messenger
Yahoo Messenger Logo
225 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
