Guest
Rank: Apprentice
Rating: 0%, 0 votes
The location of the sensor needs to be higher but my yellow wire would only pull out a couple of inches.
Turn off power to unit and remove front panel. Two screws near top/sides. Top of panel pulls out (unplug wire connector to indicator lights) and lifts off bottom tangs. Now you will see a coil of yellow wire inside unit. Remove the wire tie and you'll have enough yellow wire to locate the sensor well above the heater.
