Question about Whirlpool Refrigerators
Hello, I have a Whirlpool refrigerator that is just over a year old (Model #ER8YHMXSB00). The freezer seems to be working fine but the refrigerator will not cool below approx. 50 deg F. This just started yesterday?? Thank You..........
    Brigadier General:
  • 3,513 Answers
Refrigerators and Freezer combination units have one common compressor and coolant for both units. If the refrigerator section is not getting cold I would check the following.
The cold zone is not blocked by a bag or box? The cold zone would be the coldest part of the refrigerator which vents the cold air from the freezer to the refrigerator.
Is the fan working on the refrigerator to vent the cold air to the refrigerator? You should be able to hear it when you hold the door switch.
The thermostat is not working which I have found most common is the thermistor is not registering the correct temperature causing the fan not to turn on.
Thank You for using Fixya.com
Posted on Jul 31, 2009
LG Refrigerator model LFC20740ST Freezer is fine, but Refrigerator is not cold.
Try adjusting the thermostat knob up a bit, it should be near the leds, maybe under a cover. Seveen years is not very old but where your health might be at risk from bacteria maybe you might be justified in looking at a new machine. I refuse to call in repair people any more, once something breaks it seems to become a habit, if electrical items cna be said to have habits.
Maybe a new thermostat /seitch might cure the problem
Jun 18, 2015 | LG Refrigerators
How to replace defrost timer
a bad defrost timer can be checked with a multi meter
Sep 08, 2014 | Whirlpool Refrigerators
Refrigerator stops working until I roll the switch to off and back on
ummm hi bill.well u played with the stat and it worked for a while.so i reckon thats your problem.change stat and try good luck.ali
Aug 21, 2012 | Whirlpool Refrigerators
I have cleaned the coils this morning, but the refrigerator section does not appear to cool. The freezer seems fine. This is model eti18PKXGWI ser no. 042 9086 eemingly c. 10 years old.
Your freezer fan has probably quit. On most refrigerators the freezer is the only compartment actually cooled by the compressor and coils. The refrigerator compartment is feed cold air from the freezer compartment by way of a small fan. If you have you refrigerator turned all the way up and the door open you should here the fan running and be able to feel air moving somewere in the refrigerator compartment.
Sep 05, 2010 | Whirlpool Refrigerators
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Whirlpool side by side refrigerator not cooling
Hello danielscynt,
Welcome to Fixya,
You said, freezer is fine the refrigerator is 50-65 does not get colder than 50.the evaporator fan is working but it seems to be blowing very little air
Have a 1998 Hotpoint Model # CTX16CAZDRAD Serial # ZS738209. The refrigerator is not cooling. Temp is at 66 degrees with setting at 5. The Freezer is working, but it seems to be running all the time. Please help!
There are a few things that come to mind!
The Freezer is working, but it seems to be running all the time, you said!.
This could be a bad thermostat!
But lets try some simple maintenance first!
Is your freezer packed too the hilt with packages???????
Where the articles cover the air vents in the freezer?
The freezer and the fridge share the cold air and the passages must not be blocking the cold air from moving out of the freezer!.Search your freezer !
Also your fridge is 10 years old!
Did you ever remove the plastic grille at the bottom of the fridge along the front, and GENTLY run a refrigerator brush along the black metal tubes running back and forth under the fridge?
( You can buy this brush at any hardware store $10.)
They must not be covered in ten years of lint and dust. These narrow tubes carry the freon and run in this parallel fashion back and forth, so they are cooled by the air being **** through them.
if not and they overheat your fridge will get warm.
If the tubes are found to be covered or submerged in dust sometimes I have found them one to two inches thick in dust, and sometimes they are even not visible until you clean the dust out.
Then it will take 10 to 24 hours for the system to get back to full working temperature again. As long as the heat did not cause permanent damage!
if these are not the answer, then you may need a hands on diagnoses!
BUT, most of the time these two things are what I find!
Let me know how it goes!!!!!!!!
Thank You for asking my advice!
Huuum
Please remember to leave a rating for me!
Oct 08, 2008 | GE Hotpoint Top-Freezer Refrigerator
Whirlpool SD20 Freezer Intermittent Temperature Malfunction with Alarm Alert
Apologies, the above two guest comments are mine, not sure what happend!!
Oct 16, 2007 | Whirlpool S20DRSS33 Side by Side...
Refrigerators Logo
169 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
