Question about Epson Office Equipment & Supplies
Epson dx4000 had paper jam can not see any paper left in printer but paper jam error still flashing is there a switch or something may be sticking on or is it electrical thanks for any help given
  • prnovoa Jan 07, 2009
    After a Print command the paper initially descends but then immediatelly halts and I guet a paper jam message plus unjamming procedure request. The problem is I see no signs of paper jam - no paper sheets whatsoever are inside the printer (or bits of paper - but still the same event repeats after every print command request.
Tracing paper stuck in printer
Posted on Apr 09, 2008
My epson xp-312 will not print on photo keeps saying paper can i load when the back tray only allows one sheet of normal paper?
When a printer indicated paper jam, it means one of its sensors does not indicate a movement of paper, where it expects it. In only rare occasions the sensor is defect, but most of the time here is really a jam. This must not be a complete sheet of paper. Can be a little scrap left somewhere in the printer. Sometimes a paperclip fell in or just a paper tray was not put in place. Please open the printer and look careful using a flash light, to see if you can find anything that does not belong in the printer. Then switch it off and really unplug it for a few seconds. Reinsert the plug and switch on. If the error keeps coming back you should call a service centre, although ig you have to send it in for repairs, a new printer is probably cheaper, unless it is still under warranty.
Jan 13, 2015 | Epson Office Equipment & Supplies
My Epson CX8400 is flashing and error message that says turn off printer, turn on and see your documentation.... Far as I can see there is no paper jam and the only thing outta the ordinary is the inkset...
Whne turn on, printer move to left and right for checking carriage track, and measure it. If "something" block carriage moving, printer error occured. Check left side of carriage track. Did you use CISS?
Apr 11, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson CX3900 printer indicates paper jam
Check the paper road and paper sensor.Probably have a piece of paper or something else in the printer.
Sep 29, 2009 | Epson Stylus CX6400 All-In-One InkJet...
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
hi i hope i can help you? remove the cover from the machine and load paper as normal. and watch if the mechanics is sticking or anything that you can see give a clean with wd40clean all rollers check that you are puting in the correct amount off paper.check for loose connections.check for dirt on the switches.
May 04, 2009 | Xerox Phaser 8400 Laser Printer
"Clear paper jam" error, but there is no jam!
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
May 25, 2017 | Epson Stylus Photo RX620 All-In-One InkJet...
E4 Error It blinks all led flashing E 4 after making a jam noise, then turns off after a while
It seems your printer,s carriage is jam or carriage encorder is out of carriage sensor
Oct 15, 2008 | Epson DFX-8500 Matrix Printer
Data error
Epson DX4000 saying paper jam there is no paper in printer how can i solve this problem
Oct 10, 2008 | HP LaserJet 1010 Printer
Epson Cx3200 paper jam
Then there is something stuck in the paper feed path which is holding up the sensor flag making it think there is paper in it.
Or maybe the sensor flag has been broken off by yanking paper out the wrong way when it gets stuck.
Get your vacuum cleaner and stick the hose down the paper feed path and see if it suck out a push pin, piece of paper paper, fur ball, eraser, coin, toe nail, false eye lash etc (all of which I have removed from machines with "paper jams")
Dec 12, 2007 | Epson Stylus CX3200 All-In-One InkJet...
407 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
