Question about Generac Guardian 0A18010 - battery charger
Transfer switch will not switch back to utility
Dont know if battery charger is connected properly, will not transfer back to utility after an outage
  • 37 Answers
The transfer switch should transfer back to utility within about 30 sec. after utility is restored. While waiting for the transfer switch to switch back to utility volatge. Check for DC volatge across wires 23 and 194 in the transfer switch, if you have battery voltage(12-13.5 VDC) then you you probably have a stuck relay on the PC board in the generator. The board needs to be replaced. If you don't have battery voltage across these terminals then your problem is actually in the transfer switch.
Posted on Dec 26, 2009
    Problem Solver:
  • 5 Answers
Does the unit operate normally when there is an outtage? Don't know your system,but, guessing the re transfer delay timer is not working.
Posted on Aug 01, 2009
I recently replaced my Intermatic EJ500 with a new unit, I noticed it works perfectly fine for one day then the batteries that control the timer drain completely the following day, what could it be?
Line voltage usually controls the timer functions when properly wired until a power outage occurs; then battery power takes over until utility power is restored. Should utility power be off for an extended period of time, eventually the battery will drain completely
Double check to make sure you wired your wall switch timer properly.
Make sure there are no loose wiring connections.
Even though you purchased a new replacement timer wall switch, it could be a manufacturer's defect.
Has your home electrical system experienced any signal spikes? Electronic components are very sensitive to impulse spikes/surges and can be damaged very easily.
If you are experiencing surges or spikes, perhaps investing in a whole house surge protection system (Intermatic IG series) would be the way to go as well. It'll protect all your electronic devices and appliances through-out the house.
Feb 12, 2017 | Intermatic Hardware & Accessories
I have a 17 kW kohler generator. When the power goes out it comes on fine. When the power comes back on the transfer switch transfers back to utility power but the generator never shuts off. I have let it...
if unit is over 8 years old it has a mechanicial timer for the Cool down run time (after power comes on) these go bad from believe it not "Rust" the timer will need to be replaced with a new model , that most likely will be an electronic timer replacement , now if unit is less than 8 years old . and this is a new install then verify that ,Sense connection on terminal strip on ckt board is connected to land power
Dec 13, 2014 | Kohler Electrical Supplies
Why wont my transfer switch change back to utilities position when the power is restored?
It depends on the brand of switch and generator. A Generac has its brains in the generator control board, others in the switch, what brand of switch please?
Aug 20, 2014 | Electrical Supplies
Coils on transfer switch got fried when utility came back what could have caused this
possible failure of a relay. contact generac,sometimes they will accomodate you with new parts
Oct 08, 2012 | Generac Guardian 200 Amp Transfer Switch...
Generac 10 k battery charger installation at the generator, where does the ac input wires connect
Your electrician should have run a set of wires out to the generator from the transfer switch. The unit actually comes with a fuse holder, fuse, terminal connector, and jumper wire for installing these wires to the t1 or t2 terminals in the transfer switch. The dc wires will be the ones coming out of the battery charger, 1 of them will have a red marker around it, that is your dc positive. The 2 wires coming out of the opposite side of the battery charger is actuall your ac connection.
hope this helps let me know.
Nov 01, 2009 | Guardian Electrical Supplies
Same problem, generator kicked in after power outage,
At the point the transfer switchis suppose to transfer put a dc volt meter across terminals 23 and 194 in the transfer if you do not show 12VDC. Then you have a relay hanging upon the PCB board in the generator, need to replace board. If you are showing 12VDC and the switch is not transferring the problem is in the switch itself.
Sep 08, 2009 | Generac Guardian 100 Amp Transfer Switch...
I have a new Generac 20KW Propane generator with a rtse 200A3 automatic switch. I had an electrician install the switch and make the connections from to the generator. The generator is blowing the 7.5 amp...
Sounds like the electritian wired something wrong. Control wiring for that generator should be:
N1 and N2 = 240 vac utility input
Wire 0 = ground
Wire 194 (15B) = + battery
wire 23 = transfer signal
Sep 02, 2009 | Generac Guardian 200 Amp Transfer Switch...
Generac 4456 does not start on power loss
I install and work on these everyday. If you hooked up the transfer switch you probable have a control wire wrong. check the utility power sense wire. That lets it no when to start in auto. it could be a relay or fuses. or a control board.
Jul 01, 2009 | Generac Guardian 200 Amp Transfer Switch...
Generac Guardian 0A18010 -  battery charger Logo
274 people viewed this question
Top Generac Guardian Electrical Supplies Experts
jdthefixer
epangan29
ken skalski
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
