Question about Kenmore 500 6952 Dryer
The heating element doesn't heat up. the machine is just over 1 year
    President:
  • 1,776 Answers
When the dryer won't heat up, it is usually caused by either a faulty thermal fuse or heating element. Both of these components can be checked using a multimeter or ohm meter. The thermal fuse is located just inside the rear of the dryer and is usually attached to the exhaust duct. It is about an inch long. Check it for continuity. If it has no continuity, then the fuse is bad and will need to be replaced. Hope this helped and best wishes.
Posted on Jul 31, 2009
    Problem Solver:
  • 5 Answers
There is a short in the line runing to the heating componet you'll have to go inside the machine and find the broken wire and solder it back together
4 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: Maytag PYE3300AYW Elec Dryer Runs, But No Heat
hello kellygubser,
If you are sure the thermal switch is ok.. have you checked the high temp ( bi metal snap switch) too? Here is a link to the wiring diagram of your dryer. You can see that there are a few other temp switches in circuit of the heating element that would disble it.. Hope this helps
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Posted on Jan 09, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Performa dryer blowing heating elements
Hi and welcome to FixYa. You should check the dryer vent ducting inside and outside the dryer for restrictions / clogs to include the vent flapper. Poor air flow through the dryer will cause hot spots. If the blower is slipping on the motor shaft this too can cause poor air flow.
When you change the heating element AGAIN... break out the crevice tool and de-lint everything you can access. Also pull out the lint filter and wash it with white vinegar and water then soap and water. Fabric softener sheets material builds up on lint filters. It looks clean but air will not pass through the lint filter.
I think once you get it all ceaned up including all of the ducting to and through the outside wall it will work normally with no problems. I do not think at this time that you have an electrical problem with the outlet supply.
There is one more thing to check and that is the high limit thermostat. It could be STUCK. It will most likely be labeled L180 or L190. That thermostat is suposed to open at either 180 deg or 190 Deg depending on which one is installed. If it does not open then you will keep cooking your elements. We test them with a match and an Ohm Meter. Match under the removed thermostat CLICK. Thermostat opens (no resistance)
Wish ya the best.
Thanks for using FixYa.
Kelly
If anything in the future crops up with this same issue.
Posted on Apr 10, 2010
SOURCE: DEGX1 dryer will not produce any heat. 5 years
I have the same model of dryer and the same problem and no experience in fixing any appliances. I took a few screws off the top and the front, opened the dryer by rotating it forward, and found a red button (a fuse or breaker?) close to what I figured would be the heat sink. Pressed the button, it clicked, and decided to put it all back together. First load worked fine, hopefully that was all it needed. Good luck and hope this is all you have to do too.
Posted on Jun 05, 2010
Change element in a samung dv665j
Usually, one takes the rear cover off revealing the element area. I doubt if the heating element is burned out. Typically the small thermostat or thermal fuse link blows before the heating element goes. You would have to see the diagram of your model online. Most sites have the exploded parts view of that section online. If you don't have a meter tester you may have to replace all 3. Some models have them all tied into 1 board. This site has video troubleshooting. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067262-/Samsung-Dryer-doesn-t-heat-DV665J Samsung Dryer Doesn Heat
Sep 13, 2014 | Samsung Dryers
Testing & replacing a dryer heating element
First you have to determine whether you element is in the front or the back of the machine this is done easiest by looking at the front of the machine and seeingif its one complete piece or two. If its one, the element is in the back, if two its in the front. We'll start if its in the back first. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced. Now if the element is the front everything is the same with the exception of you have to remove the lower portion, usually held on by 3-4 screws located underneath.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 04, 2012 | Dryers
No heat in dryer.
May 26, 2012 | Kenmore Dryers
Kenmore dryer not heating
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced
Apr 28, 2012 | Kenmore Dryers
Dryer wont heat
Apr 26, 2012 | Whirlpool LER8648P Electric Dryer
Dryer not heating up
Apr 24, 2012 | Whirlpool Dryers
No heat
Mar 14, 2012 | Kenmore Dryers
No heat
Feb 08, 2012 | Kenmore Dryers
My kitchenaid dryer won't heat up.
Dec 31, 2011 | KitchenAid Dryers
I have a bosch diswasher which is quite a few years old no sgs3042gb/03. the water isn't getting hot and it doesn't dry?any help will be grateful
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 13, 2011 | Bosch Dishwashers
Kenmore 500 6952 Dryer Logo
233 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
