Question about Protron PLTV-37 37 in. LCD Television
What difference between broadcast supported and broadcast displayed
I had LCD Tv and it says broadcast displayed 720p and broadcast supported 1080i. it makes me confused. could u guys help me out this confusing.thanks. TV is samsung.
  • 58 Answers
1080i is yesterday's resolution and now it's up to 1080p as the standard.  Who knows where it may end up.  I suppose there will be 3-D actors prancing around the living room.   Wee.
Good luck.
www.proton-usa.com
Posted on Dec 06, 2007
What pixel is this tv 780 or 1020
http://www.amazon.co.uk/Philips-32-5331-HD-Ready-LCD/dp/B000IUZ944
  • Resolution: 1366 x 768 pixels
  • Display Format: 720p
  • Supported DTV Resolutions: 480p, 720p, 1080i, 576p
If this helps or solves the issue, please rate it and give a testimonial for my response.
Thank You,
Brandon
Dec 22, 2010 | Philips 32PF5331 32 in. HD-Ready LCD...
How do i change the resolution from 750 to 1080
If you are watching over the air channels via an outdoor antenna, the display resolution 480i, 480p,720p or 1080i is set by the broadcaster. If you are connected to a BluRay player, HD cable box or satellite box you need to set the resolution in the source not the TV. The TV only diplays what it receives..Hopefully that was clear...
May 18, 2010 | Vizio VO37LHDTV10A 37 in. LCD TV
TV set always starts up indicating 420p. How do I get it to 1080?I have Bell expressvu HD
is your cable or sat in HD(720p, 1080i, 1080p) over the air broadcast in the usa is in digital so it should start at the highest res available in your area
next are you using HDMI or composite for your cable or sat going into your tv if not your not going to get higher than 420p because A/V and S-video do NOT support HD
check your cable/sat box is it HD(high def) or SD(standard def) if SD going through cattv/attn in your only going to get 420p
now for changing the resolution its automatic it goes to the highest setting on its own
you can control the resolution through your cable/sat box, blue ray/hddvd player and other HD devices connected to the tv through the options menus of those devices BUT only when connected through
HDMI(supports 720p, 1080i, 1080p)
composite(supports 420p, 420i, 720p)
A/v and S-video(supports 420p)
cat tv/attn in(supports 420p, 720p, 1080i, 1080p) only supports what the tuner will do
i=50hz
p=60hz
Feb 11, 2010 | Hisense LHD3204US 32 in. LCD HDTV
I have a problem with using the HDMI
Please make sure that your receiver can display high definition signal, such as 720P, 1080P. As you know your HDTV is high definition source, it can only be displayed on the display machine that have ability to display high definition HDTV signal.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Even when I receive HDTV chanels, the display reflects only 480.
No adjustments can be made on the TV since the channels are being pick up with the resolution they are being broadcasted. Once the TV tunes to a digital channel(s), it will show the resolution to be either 480i, 720p or 1080i
Jun 16, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Is the protron pltv32cm a high definition tv . I bought it in 2005.
Kind of. It is capable of 720p. So channels like FOX, the ESPN channels, SPEED, and other 720p broadcasts will look fantastic on that display. However, the 1080i broadcasts will be shrunk to fit your screen. They'll still look pretty good, though. Most people consider HDTV to be anything above & beyond 480p (so, 720p, 1080i, 1080p).
Apr 07, 2009 | Protron PLTV-32 Television
How to change from 480i to 1080i
The TV has a automatic scalier chip installed so it depends on the input signal that you are using. For example you are using a HDMI connection with a xbox 360 and you set the display setting to 720P then the TV will display it in 720P. If you set it to 480P then it will display it in 480P.
Apr 01, 2009 | ViewSonic N2635w 26 in. LCD Television
1- I have a Panasonic TV (PT-53TW54)that has a "digital scan rate of 1080i,540P". I'm not sure if that means it has a digital tuner. Do I need a digital converter for this unit? 2- I'm using a...
1. Do I need any additional equipment to watch HDTV broadcasts on my HDTV-compatible TV?
In order to view over-the-air (OTA) HDTV broadcasts, you need to be within the reception area of a TV station broadcasting HDTV signals. Some TVs may require a set-top HDTV tuner and an external antenna to receive the broadcasts. Your cable or satellite provider may also offer HDTV channels as a part of their service, eliminating the need for a separate tuner. Please contact your local service provider to find out what kind of HDTV services they may offer.
2. What is CableCARD and how does it work?
HDTVs with CableCARD slots can accept a small card from your cable provider that allows you to receive standard definition and high definition digital broadcasts without a bulky set-top cable box. Please call your cable company to find out if they offer this service in your area.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif3. What is HDMI? Is it compatible with DVI?
HDMI, which stands for "High-Definition Multimedia Interface", is the consumer electronic industry's first connection capable of transmitting uncompressed digital audio/video signals. Components featuring HDMI can transmit both digital audio and video over one convenient cable, replacing the tangled mess that resides behind many home theater components. HDMI also offers improved quality over traditional analog connections thanks to all-digital transmission. Digital sources like DVDs and HDTV programming can now be transferred digitally from source to display without analog conversions that can degrade the original signal.
Unlike the HDMI interface, DVI only handles digital video. Through the use of an adapter, a DVI device can be connected to an HDMI device, but only video content can be transmitted. The audio signal would have to be transmitted through other methods such as analog RCA outputs or an optical digital output.
4. What's the difference between 720p and 1080i HDTV broadcasts? Does my CRT projection HDTV support both?
HDTV signals can be broadcast in either 720p and 1080i. It's up to the broadcaster which signal format to use, and both have their benefits. Our CRT projection HDTVs display 1080i signals in their native format. For 720p broadcasts, you can use the settings on your HDTV set-top tuner, cable box, or satellite tuner to convert a 720p signal into a 1080i signal that your TV can display.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif5. Why do I still see black bars on my widescreen TV when viewing certain widescreen DVDs and HDTV broadcasts?
Your widescreen TV has an aspect ratio of 16:9 (1.78:1), which is the aspect ratio of HDTV. However, movies are filmed at several different aspect ratios, including 2.35:1. Also referred to as "scope", 2.35:1 is a very panoramic aspect ratio that provides a wide field of view in the theater. Scope is much wider than your widescreen TV, so it still requires the use of letterboxing ("black bars") to fit the entire image on screen. Some TVs and DVD players have a zoom function that allows you to blow up the image so it fills the screen, but the sides of the image must be cropped in order to do so.
6. What will 4:3 broadcasts and DVDs look like on a widescreen TV?
There are multiple settings for adjusting the appearance of 4:3 material on Panasonic widescreen TVs. It can be viewed with black bars on the sides, preserving the way it was originally intended to be viewed. Some viewers find the black bars distracting, so they might prefer one of the stretch modes that lets you fill the entire TV screen with the image. One such mode is the JUST (justify) mode, which stretches only the outer portion of the picture while leaving the center untouched.
Oct 21, 2008 | Panasonic Televison & Video
I can't get the 1080p resolution to my insignia tv. Anyone can tell me how to do it pleaes?
that's because the TV's are ahead of the technology. Cable TV does not broadcast anything in 1080P yet;
Feb 02, 2008 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Protron PLTV-37 37 in. LCD Television Logo
49 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
