Question about Refrigerators
My 80yr old father is complaining that the ice maker doesn't make enough ice in the summer. i have no problem in the winter. how do fix both
  • mccrave7 Jul 31, 2009
    update found out that the 10yr old refrigerator is not making ice at all
  • 286 Answers
Ambient temperature can play an important role. What make and model is this? Is the unit outside? Lets start there.
Posted on Aug 03, 2009
Electrolux Ref. 3yrs old. ice maker will not make ice, water dispencer will work. I have replaced filter.Ice maker goes through the motion but, no water. can you help me?
either your fill tube is clogged or the water valve in the back of the refer has failed. Go to the back of the unit, if my memory is correct the yellow hose is for the ice maker, at the water valve disconnect the 1/4 hose from the valve to the ice maker only, place valve in a bowl, cycle ice maker. If you get water, fill tube is obstructed, if not water the valve has failed and needs to be replaced.
Good Luck
Oct 28, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
My refrigerator model tbx22rg works great at winter but at summer doesn't work at all, Why?
Its not even a refrigerator you dumb egyptian ****.. SOME ONE SOLD YOU A REFIGERATOR BOX~!!!
Aug 04, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
My scotsman model 506as 1f, serial no. 06021320015994. Was running fine until i had it sent in to a local shop for routine check up during the normal winter down time for the machine. When i started using...
Have you pulled the cover off so you can see the code it is giving really need to know it. sounds like either low charge or hot gas valve not opening during harvest. I really need the code to be able to help you out.
Jul 07, 2011 | Scotsman Ice Maker CM3 30inW Cubed Ice...
95 Jeep Grand Cherokee. A/C only blows heat. Dealer mechanic says something broken in dash and very costly to fix--not worth the money on old vehicle. If clamp heater/radiator hose, can get partial AC,...
Put an small brass butterfly valve in the heater line, on both sides. That will turn it off for the summer, and you can turn it on for winter. Alternatively, you could try and do like I'm doing on my '59 Chevy, when I get it out of the flood plain, and route ice water through the heater core.
Jun 05, 2011 | Jeep Grand Cherokee Cars & Trucks
Ev201nxm door doesn't seal/ices up
I have a EVL201NXRQ05 upright whirlpool. It was purchased in Nov 2008 in the Summer of 2009 the gasket was leaking at the top of the door. The gasket on this door snaps into place (no hardware needed). The problem is the door was bowed in the middle pulling the gasket down and away from the metal frame of the freezer - to the point the magnets in the gasket would not touch in the middle of the opening. I requested a new door while under warrantry. The door did not appear to be repairable it is a glued/foamed-inplace assembly. The new door looked straight when I installed it last summer and now it is bowed but not yet leaking. Whirlpool has a design / manufacture problem with this door design. I have received an extended warranty option from Whirlpool this past week 4 months after the factory warranty has expired. I suspect they know they have any issue, but not much is written about it. I may end up buying the extended warranty, but first I'm going to where I bought it to complain.
Jul 03, 2009 | Whirlpool 19.6 cu. ft. Commercial Freezer...
Ice maker has quit making ice
Lower the freezer temp. The icemaker won't come on until the temp is low enough.
Mar 10, 2009 | Fisher and Paykel E522B Stainless Steel...
Ice maker too slow
Ice makers will only drop cubes about every two hours. There is nothing you can do to speed it up. However, if you have low water pressure to the fridge, then you will have slow production. You need a minimum of 30-40 pounds (constant) of water pressure to the fridge for the ice maker to work properly. Things I typically see causing low pressure are: Self piercing saddle valves on the water line (need drill type), and reverse osmosis systems connected to the fridge. In some rare cases a very old water filter or limed up supply line.
Jul 06, 2008 | Samsung RB215LASH
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
