Question about Canon PowerShot A620 Digital Camera
Black LCD screen. Nothing in LCD screen. No photo on card. When connected to computer, black images appear, no photo. Problem?
I took a hammer to the shutter - now it opens! Actually, I tried the suggestion and it did not correct the problem. I guess I will have to get a new camera. Very disappointed as this camera is only four years old and well cared for.
Posted on Aug 03, 2009
Canon powershot sx10 cannot download
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as iPhoto.
Jun 21, 2012 | Canon PowerShot SX10 IS Digital Camera
Black screen no image showing
black screen blur image showing cannot see subject to be photographed when camera power on,if press to take photo nothing shows, just black screen. it was fine one minute then nothing the next. battery is fully charged, memory card ok.
May 24, 2010 | Olympus FE-230 Digital Camera
Is on but black screen
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 24, 2009 | HP Compaq Presario CQ50-110US Laptop
Black screen when turn on the computer
The problem could be a loose video cable/connector.
Reseat the video cable or the connector that connects to the motherboard.
To check if the video card is faulty, connect an external monitor to the video port on the HP, power up the external monitor first, then bootup the laptop. The video will automatically switch to the external monitor and if you see a normal image then the video card is OK and the fault is the LCD screen/video connector.
If you see a faint image when you view the LCD screen at a sharp angle, then the fault could be the CCFL lamp or the inverter that supplies high voltage to the CCFL lamp.
Sep 01, 2009 | HP Pavilion dv1000 Notebook
Can't get a picture on the screen - just shows black. When we turn the camera on the LCD screen displays the function choices and menu options, but will not display any image. If we take a picture using...
Check the SD card, they have sliders on them which lets you "lock" the card so nothing can be put on or taken off of it. Make sure that is off. Then go through the menu on the camera and try to format the card again. If the card is bad it should give you an error message when it tries otherwise you should be good :)
Aug 19, 2009 | Canon Powershot A1000IS 10MP Digital...
A95 LCD screen black and unable to take photos
Its common problem in canon cameras and I have solution. please let me know if you didn't find in chat.
Sep 02, 2008 | Canon PowerShot A95 Digital Camera
There are quite a few of us with symilar problem, but the screen is not completely black: it has some purple or pinkish color when facing light. Old pics and menu can still be viewed. I noticed 4 symilar threads on Canon A95 within the last 5 mins without any search, just looking at the top questions.
Aug 09, 2008 | Canon PowerShot A95 Digital Camera
Nikon Coolpix S1 - Need help.
This is a common, but unfortunately fatal problem with this model camera. Don't worry, your photos (if taken on the sd card) are all still safe and sound. Just transfer your photos to your computer.
There is nothing you can do that I know of to fix this. But there is a guy (I call him, "the cheap camera repair man"), who fixes this problem for thirty dollars. The website URL for him is:
http://www.dynamiccamera.com
I hope this helps!
Jan 04, 2008 | Nikon Coolpix S1 Digital Camera
Screen appears black
your camera has a broken image sensor i.e. CCD. contact your nearest camera repairer to change the same, the only solution.
Jun 29, 2006 | Vivitar ViviCam 8300s Digital Camera
Canon PowerShot A620 Digital Camera Logo
160 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
