Question about Cell Phones
My samsung slyde from telus wont work
I turned it on, the welcoming screen came on for a moment, but then the screen went blank! the phone still makes sounds, and the letters and numbers are stil lit up but i cant see what im doing! please help!
My samsung cell phone is a R740cthe it trurs on an shows samasung on the screen then gos blank an screen stays lit up but shows nothing it was working one moment not the next ?
THIS WOULD PROBABLY BE AN INTERNAL PROBLEM YOU PROBABLY CANNOT FIX.SOME TYPE OF INTERNAL CONNECTION OR GROUND.YOU PROBABLY WILL NOT BE ABLE TO DO ANYTHING UNLESS IT IS UNDER WARRANTY
Jul 14, 2014 | Samsung Cell Phones
Telus phone wont turn on
Hello sir!
Your phone's IC has been burnt go to some mechanic and get it repaired.
Thanks
Jul 20, 2012 | Samsung Cell Phones
MY SONY TV LCD MODEL KF-50WE620 screen went blank. When I turn on the green light it blinks on 40-46 times every second, then turn to red color to Stand mode and blinks for 160 times, then move to power...
There is no reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Tom Miller
Broadcast Eng
Mar 04, 2011 | Televison & Video
Just got my Samsung Impression and it was working fine until the screen randomly went blank. When I turn the phone on I see the start up for about 3 seconds and it turns off. I can take photos and I see...
Hi,what makes Samsung impression phone to go blank is because the flex of the phone is damaged.
The flex of the phone is located inside the phone, connected to the screen board and allows the screen to display.
When the flex get cut or damaged it will make the phone not to display.
So you will need to replace the flex of the phone and problemwillbe solved.
Take care.
Oct 07, 2010 | Cell Phones
Okay, so i recently bought a Samsung Slyde SPH-M54...
I just repaired my son's phone with the same problem. Turns out the Micro USB connector on the phone was completely un-soldered from the PCB. I simply had to solder it back on to get the battery to charge. You will need a soldering iron with a sharp tip and a steady hand. The connector is in a tight space.
May 20, 2010 | Cell Phones
Sam U450
if it still happens when you take the sd card out than it is a device issue and you need to turn it off and back on. if the powercycle doesnt work contact your provider about replacements because it is a device issue. if it works without the sd card, first make sure the sd card is compatible w/ your phone by checking your manual. if it is then the sd card is bad and you should take it back and get a new one.
Mar 14, 2010 | Samsung SCH-U450 Cell Phone
Nobody can hear me when I call on my samsung slyde cell phone.
Your phone speaker is broken just use handset or replace your phone mic
Aug 20, 2009 | Cell Phones
How can i fix my Samsung Slyde (Rant)
Just make some rice, and put it in a ziploc bag. Then take out the battery in your phone and put your phone without the battery in the bag. The steam will help get the water or tea or whatever out. I've done this before and it helps a lot!
Jan 03, 2009 | Cell Phones
Lg vx8100
I do not have a suggestion for you, only sympathy. I have been putting mp3s on my phone for about 3 months and there are always a few that seem to be corrupted. They will either not play or more commonly cause my phone to reboot. (even though they work perfecly when burned to cd or played through vlc or winamp) It goes to the telus startup screen and stay there until the phone flashes off and back on. I have tried re-encoding the mp3s with no change in performance. I wonder if anyone knows of a different media player for this phone. Have you called Telus? I know they are a pain to deal with but there may be options. Alternatively I might suggest flashing the firmware and starting fresh.
Aug 28, 2007 | LG VX8100 Cellular Phone
Cell Phones Logo
476 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
